6E lean idle, mild cam tuning help
Old Oct 8, 2006 | 06:44 PM
busta9876's Avatar
Car: 1967 C10 Pickup
Engine: LMM Duramax
Transmission: 4L80E
okay, tuning a 355 with a mild cam, blm's are in line driving and such.
Hot IDLE blm's go to 160.
8 gm/s blm of 147
10 gm/s blm maxes 160
15 gm/s blm comes down some
around 24 gm/s blm is back around 128-130
should I adjust the MAF table 1 to indicate higher air flow readings?
i'm new to this, i've read the guides, not much stuff on $6E tuning.
also, on warm startup, engine reves to 1700 before coming back down to normal idle. warm IAC steps is around 25 for 180 degree where the engine was at.
Old Oct 8, 2006 | 07:56 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Check for air leaks between the MAF and TB, and check for any vacuum leaks. Then see if the MAF is "gutted". Then, a faster way to the end goal may be to raise the Injector offset vs VBatt a little. Try adding 0.1ms at a time, and see if it helps. That table has more of an effect at idle and low loads.
Old Oct 8, 2006 | 09:57 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
How much overlap does that mild cam have? It doesn't take much at idle to fool the O2 sensor into thinking the AFR is lean.
I had to put in a CAL value in the MAP code I run to not do closed loop below a certain RPM. That is with a mild cam and -4* @ .050" of overlap.
Old Oct 13, 2006 | 03:49 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
You are probably not lean. The narrow band O2 sensor can not accurately read exhaust at idle if your cam has enough overlap to fool it. I have the exact same problem, and I've been working on it for over a year. My solution is going to be to buy retro roller lifters and get a roller cam. Is your cam flat tappet? If so, you may be stuck fudging like me, and the BLM is just going to hang at 160 for idle. You can still tune around the BLM being maxed at idle.
Old Oct 13, 2006 | 09:39 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
flat cam..
it causes real trouble when it is hot with hot air temp also, loads up...this sounds like my problem.
wonder if way to disable closed loop idle.
I guess if everything else is close, i can change max BLM / INT value to a lower...say 140 instead of 160..that should greatly improve hot idle problems.
Old Oct 14, 2006 | 11:08 AM
Car: 2000 BMW M5
No easy way to disable closed loop idle in 6E unless you can write assembly. You can cap the BLM at 140 and then adjust your MAF around idle until you get it to do what you want. You're going to be stuck doing that with a flat tappet cam that idles dirty.
Old Oct 17, 2006 | 12:17 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I added some timing last night at idle and the blms came down from 160 to the 140's. Don't know if it will work for you or not,but it's worth a try.
Old Oct 18, 2006 | 09:55 AM
Car: 2000 BMW M5
How much timing are you running at idle now? I already idle at 26 degrees.
Old Oct 18, 2006 | 11:05 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
39 degrees
Old Oct 18, 2006 | 01:12 PM
Car: 2000 BMW M5
Wow that is a lot of idle timing. I think I'd be terrified to run that much with my 9.7:1 static compression.
Old Oct 18, 2006 | 02:33 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I don't know if it's just my car or what, but the conventional doesn't seem to work. I don't have enough seat time on this tune (just down the block and back) to determine if it's ok or not, but before I changed it to 39, it was at 33.
Old Oct 18, 2006 | 08:32 PM
Extra timing at idle WON'T damage an engine easily, so don't be afraid of it for that reason. One problem though is that it makes the engine more efficient, which can reduce INJECTOR PW to an unstable point in the linearity aspect (if you have larger injectors). Having high timing at idle, near MBT timing, can also reduce the effectiveness of idle stability spark advance algorithms from working, but I don't think $6e has that. Another problem is that snapping the throttle open from idle may allow a few really advanced sparks before it realizes the extra load, and may knock really hard.
BUT, I'm not opposed to adding plenty of idle timing to help a cam smooth out at all. It's what it needs. 39 may be a lot, but it's your engine, not mine! Try it and find out if it's acceptable.
Old Oct 19, 2006 | 07:53 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Upping the timing has also helped to reduce the stinky fuel smell at idle.
Old Oct 20, 2006 | 12:44 AM
There's a Closed Loop Rich/Lean Threshold vs. Airflow table at 046B that you can use to target a much leaner voltage at low airflows. Try targetting ~200 mV at the lowest 3 airflow entries.
It may also help to raise your target idle RPM a little.
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
