Got moates E6 working, need help analyzing
Old Oct 6, 2001 | 09:44 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Ok, finally got my GTA back on the road again. No, the big gofast parts aren't on it yet, but I want to start learning how to tune properly.
I have a csv at <A HREF="http://people.mw.mediaone.net/afgun/gta/arap-c.csv">http://people.mw.mediaone.net/afgun/gta/arap-c.csv</A>. I need some help figuring out how to relate this to alterations to
my arap binary.
Mods include:
n/o change
disable egr and diagnostic
adjust fuel injector contstant to 26lb/hr (via winbin) - i use svo 24#
In case you want to peek at it, it's at
<A HREF="http://people.mw.mediaone.net/afgun/gta/arap-c.bin">http://people.mw.mediaone.net/afgun/gta/arap-c.bin</A>
My BLMs are almost all very high, leading me to believe that I need to take fuel out of the chip wholesale.
Which injector constant do I use? single-fire or double-fire? The hac file wasn't very helpful in that regard either.
Teach me
PS This was using E6 and a different laptop. I'm thinking that my previous attempts at logging with Moates' new version were due to either the Toshiba laptop, or a bad memcal. I'll test the latest Moates tomorrow after I do some chip tuning with your advice!
Old Oct 8, 2001 | 10:26 PM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
If your BLMs are high, then the ECM is adding fuel, meaning your basic calibration is lean. Making your injector constant smaller will make the BLMs go down. Keep both constants identical.
Old Oct 9, 2001 | 02:07 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Thanks. So I'm lean, need to increase FP or lower injector constant. Figures my isolator puked and my FP gauge isn't working.
Why keep the constants the same? If one isn't used, why do anything with it? Just trying to learn...
TIA!
Azrael91966669
25
Jun 20, 2017 04:04 AM
dahlman
Nov 3, 2003 07:27 AM
Morley
Oct 9, 2003 04:23 PM
clippjr8
Feb 18, 2003 02:48 PM
atc3434
Feb 7, 2003 07:11 PM
