Is there a way to see how much the ecm is advancing timing?
Old Oct 18, 2001 | 11:56 PM
JPrevost's Avatar
Car: 91 Red Sled
Is there a way to see how much the ecm is advancing timing? There are a bunch of tables that aren't in tunercat and I'd like to know how to either calculate the advance by temp, rpm, map or is there something in the aldl data stream that tells you?
This is for the 8746 ecm or 7747 TBI.
, Jon (350 TBI!)
91 Red My website
Old Oct 19, 2001 | 07:42 AM
fast_broker's Avatar
Ya know, I don't think the spark data is in the data stream. I guess one could change the PROM pretty easily and output that parameter instead of some other useless info... That would be NICE
Old Oct 20, 2001 | 03:42 PM
JPrevost's Avatar
Car: 91 Red Sled
How would one go about chaning the prom?
, Jon (350 TBI!)
91 Red My website
Old Oct 20, 2001 | 05:47 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Jon, if you have the HAC and know the RAM address for spark is, you can calculate it and put it in the ALDL stream. BUT, I have no idea what the RAM address would be for the spark advance. The ALDL list is actually defined in the PROM, and can be changed to show whatever you want!
I kinda like the idea myself, actually...
Ken
Old Oct 20, 2001 | 06:46 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by JPrevost:
</font>
You need a fully commented hac, not just the calibrations, the whole thing.
Then look at the memory (RAM) addresses used in the ALDL stream, then substitute whatever items (by ram location) that you want to look at. Then make the changes in the scan tool to read the new ALDL strea. FWIW, I double entry my O2 so I can keep closer tabs on it with my scanner / data logging.
Old Oct 21, 2001 | 04:05 PM
JPrevost's Avatar
Car: 91 Red Sled
Grumpy, would you be able to input that parameter into the 7747 prom? If so I think I'm going to go to the 7747 ecm.
Old Oct 22, 2001 | 07:42 AM
That ECU has been hacked to death. It's gotta be an easy change... For someone who knows what they are doing, that is...
Old Oct 22, 2001 | 11:04 AM
JPrevost's Avatar
Car: 91 Red Sled
Well help a brotha out
Grumpy, have you the ability to do this?
, Jon (350 TBI!)
91 Red My website
Old Oct 23, 2001 | 04:47 PM
JPrevost's Avatar
Car: 91 Red Sled
ttt, I'd really like to know how to do this. I've looked on diy-efi.org but I don't have the time to read ALL the past posts and the searching the archives hasn't turned up any useful information.
, Jon (350 TBI!)
91 Red My website
Old Oct 23, 2001 | 05:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Grumpy, would you be able to input that parameter into the 7747 prom? If so I think I'm going to go to the 7747 ecm.</font>
Nope. I don't have a fully commented Hac of the 747. You need a version that also shows the RAM locations. Your talking about one that someone has spend months on.
Old Oct 23, 2001 | 06:12 PM
How about the ASDZ one on DIY??? i thought that was a full hack???
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
