730 tuning with Craigs software
Old Oct 23, 2001 | 08:43 AM
Tomcat's Avatar
Well I had my first go tuning my 730 using Craig Moates software - awesome scantool !
I am a bit lost though on the BLM cell as it appears to use the same cell 4 for idle and some of the higher rpm stuff as well and it drops in and out of different cells without the map voltage or rpm changing ??
Are the actual cells relevent or do you just tune to the BLM ? to achieve 128.
Is there any calculation for map voltage to kpa so that I know what map value to adjust ?
Is there any calculation software like ve master that works with the 730 ?
Sorry for all the questions but I have only just got this vehicle and its a lot different to my previous ride that used a map version of the 165.
Old Oct 25, 2001 | 06:58 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
<font face="Verdana, Arial" size="2">Originally posted by Tomcat:
</font>
I hope this isn't too late but I took some readings today at work from a 92 S10 4.3L and this is what I found:
KPA Volt
16 .30
20 .54
25 .75
30 1.08
35 1.32
40 1.65
45 1.80
50 2.10
55 2.44
60 2.65
65 2.98
70 3.20
75 3.50
80 3.80
85 4.10
90 4.35
95 4.55
100 5.00
103 5.02 (we're actually under sea level in SoFLa)
Some of these values I couldn't get exactly so I did like the ecm and interpolated. Take these numbers FWIW as I don't think they should be set in stone.
Old Oct 25, 2001 | 07:10 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
So:
KPa = (18.23*Volts) + 10.9
? Anyone confirm? Looks like a nice relation...
Old Oct 25, 2001 | 09:27 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
I will take some readings from another car and see what matches and what doesn't. These readings were taken by a Snap On MT2500 scanner. It shows map and baro readings in kpa and volts. If only they would divulge that information. I have a semi working ecm bench and a vacuum pump but I couldn't get the map to work. I wish it were an exact thing but like I said I kinda interpolated some values I couldn't get exactly. I did notice there that it kind of went up .3 volts per 5 kpa.
Old Dec 31, 2001 | 05:09 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Originally posted by Craig Moates
So:
Craig, did you ever get an answer to the above?
I've been using your ECM845 program on a SD system for about a week now. I'm using Excel to sort the data and use the above formula to convert the voltage for kPa MAP readings. I'm sneaking up on the ideal 128/128 but it's a slow process.
Do you intend to integrate the formula into your program when you verify it? Also, check your PP account.
hectorsn, those values seem pretty close to the MT2500 I'm using but Craig's program allows MUCH easier tuning with the data capture.
Old Dec 31, 2001 | 06:29 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
No doubt Craig's software is much better and the price is much better than the "red brick"! But did you know that SnapOn has software that enables you to hook the brick up to a lap top and do pretty much what Diacom and those guys do. It's somewhere along the lines of $400 which doesn't seem unreasonable. I'm sure if Craig had the time he would put it in, but since the formula works out well and you have to put the data in excel anyhow..... Maybe for the next update.
Old Dec 31, 2001 | 08:54 PM
kevinc's Avatar
Car: 1982 Z28
I've been tuning using Craig's software, calculating KPA as [(MAP*100)/5] where MAP is the reported MAP sensor voltage output.
Opening the CSV file in Excel, I just add a column and insert the formula above into it across the whole capture.
-Kevin
Old Dec 31, 2001 | 10:19 PM
SMasterson's Avatar
Car: '89 GMC Pickup
-Kevin
I use Excel and add the column, just like you. But. . . I use the formula Craig has above (KPa = (18.23*Volts) + 10.9) and checking it with hectorsn's readings from the Snap-On scanner I come out very close. I was WAY off when I used your formula. Where did you get it?
Thanks,
Old Jan 1, 2002 | 02:00 AM
Car: 87 T/A
Did I put that into 845? I forget. I thought I put the kPa calc in there then. Someone refresh me.
If it needs to go in, lemme know and it'll go. Might be time for a revision. Any suggestions for other functionalities?
-Craig
Old Jan 2, 2002 | 11:51 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Craig, can you add the IAC counts to the list of data on Item (or whatever it's called) 4? I know it's recorded when the data is logged and I think it's under the label ISSPMP. Other than that, great job! Oh, this is for the '165 ECM.
Zell1luk
Sep 29, 2015 10:36 AM
