Pocket programer
Old Nov 1, 2001 | 04:38 PM
righton's Avatar
Pocket programer
What is the trick getting the med-cal to verify to pocket programer. I can get it to verify after moving the med-cal several times in different directions.I lock the med-cal adaper into the pocket programer and then insert the med-cal , but osftware does not verify the med-cal. What I'm I doing wrong JOE
Old Nov 1, 2001 | 07:20 PM
davidjon_99's Avatar
<font face="Verdana, Arial" size="2">Originally posted by righton:
What is the trick getting the med-cal to verify to pocket programer. I can get it to verify after moving the med-cal several times in different directions.I lock the med-cal adaper into the pocket programer and then insert the med-cal , but osftware does not verify the med-cal. What I'm I doing wrong JOE</font>
I'm assuming that you mean mem-cal (memory calibration) when you say med-cal.
You have to have a program in the pocket programmer's software buffer in order to verify the prom. In order for the verification to be successful, the program in the prom and the program in the buffer have to be exactly the same.
1991 Chevy C2500HD 5.7L HD. 16147060 ECM
Mods: Crane PowerMax 2030 cam 204I 214E @ .050 and 423I 446E lift, Jacobs Pro Street Ignition System. Using DataMaster and TunerCat with $85 ECM files.
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
ULTM8Z
Oct 2, 2015 01:25 PM
anesthes
Sep 21, 2015 10:24 AM
