ALDL to Laptop circut
Old Nov 2, 2001 | 10:53 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
ok here's the webpage for the circut i'm using
[html]http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm[/html]
my question is would it be ok to leave this plugged in all the time. example, i have it plugged in to scan with my laptop but then just disconnect my laptop and leave the circut hooked up to the ALDL connections. what i'm wanting to do is actually splice the ALDL wires from behind and put the circut in the dash somewhere and just have a 9 pin serial port on my dash where that "Extended Range" emblem used to be so i can just hook up my computer without worrying about hooking the circut up every time
thanks
Andrew
Old Nov 3, 2001 | 07:33 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
You will be ok as long as the circuit design does not have a constant connection between terminals A and B of the ALDL because that will make the ecm act differently. Essentially, if A and B are not touching, what you plan to do is the same thing the factory did: a plug for diagnostics.
xodus2002
Jul 17, 2020 09:08 AM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
greenyone
Sep 8, 2015 08:41 PM
Gunsbee
Sep 7, 2015 07:10 PM
