Hex Address for Shift Light
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd like to change that stupid shift light, so it doesnt come on under 2000 rpms anymore. I know it can be done, but I dont know the hex address for it. TunerCat doesnt list it anywhere. I have a map for a Corvette chip, but it doesnt match up with my f-body chip. Does anyone know where it is, which byte address, so I can change it to not come on except over 2200 RPMs, and also change the upper limit so it comes on at 5500 RPMs? Thank you!
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I wouldn't mind knowing this info if somebody knows where it's at
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Car: Death Mobile
Engine: 666 c.i.
The only addresses I am aware of is in the $8D.hac from GMECM Guy's website. That is for the ANHT Corvette BIN. To my knowledge, the data area is the same.
I wonder if auto cars even have a shift light in the dash! Or maybe it's there but w/out a bulb in it. I'm gonna have to check that out.
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
I have the hex adresses for the 89 code the ARAP.bin I believe
will these do?
1986 IROC 350 5spd
just installed a TPI from a 1988 IROC, 24# lt1 injectors,165 ECM MAF, custom sub frame
www.members.home.com/v8power/
GOT TOURQUE ?
will these do?
1986 IROC 350 5spd
GOT TOURQUE ?
Wow, this is an old post. I already found it and changed it and forgot about it a long time ago.
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal F-Bodies
1991 Camaro Z28
317 RWHP, 418 RWTQ
Southern California
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by v8power:
will these do?
</font>
will these do?
</font>
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Yeah like me
I looked at both hacs for the $8D and the one on ECMGuy's page has a "shift light code" routine but the other hac doesnt have one at all!
Kevin, would you be so nice as to share some info ? What do you need to change and how ? Thanx in advance.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You will need Tuner Cat's TDF editor.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
This is the info I have:
LC290: FCB 128 ; 56C, (132f) COOL THRES FOR L.U.
; OR SHIFT LIGHT
; E LIGHT PARAMS
LC2ED: FCB 120 ; 50C, (122F) MIN FOR LIGHT ENABLE
LC2EE: FCB 47 ; 47 MPH MIN FOR LIGHT ENABLE
LC2EF: FCB 0 ; 0 TPS MIN FOR LIGHT ON
LC2F0: FCB 0 ; 0 LV8 MIN FOR LIGHT ON
LC2F1: FCB 56 ; 1400 RPM THRES FOR LIGHT
LC2F2: FCB 208 ; 5200 RPM FORCE LIGHT ON
; OR SHIFT LIGHT
; E LIGHT PARAMS
dhonda200
Aug 11, 2015 11:50 PM
