WinALDL 1.04a released
Old Dec 12, 2001 | 09:03 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
http://www.winaldl.webhop.net
* Added support for 1227170.
* New "Are you sure?" dialog when terminating the program.
* Buggfix 1227808 uses a new IAT calculation.
* Buggfix Odd behavior on the [Esc] and [Enter] keys.
Jonas Bylund
Old Dec 12, 2001 | 03:46 PM
nsimmons's Avatar
did you fix the bug that happens when you click on the x to close it and the data logger comes up?
1984 Z51 Auto, Ported and polished intake, K&N, MSD, Ram air/Cold air intake, no cat, no AIR, no egr, no swirls plates
Old Dec 12, 2001 | 06:37 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Yes, that was the same bug that brought up the data logger on the [Esc] key.
Jonas Bylund
Old Dec 13, 2001 | 02:12 PM
Jza's Avatar
Jza
Excellent software.
Maybe you should think about sort of making it modular so you can "plug in" new ECM types without having to recompile the program.
Old Dec 13, 2001 | 02:39 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
That is a good idea, but I will have to re-write a lot of code to do it.
I have been thinking about using XML to describe the ECM data.
Jonas Bylund
Old Dec 14, 2001 | 04:15 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Ver 1.04b Buggfix 1228746 use the same IAT calculation as 1227808.
Jonas Bylund
Old Dec 19, 2001 | 09:35 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
I just released ver 1.05a.
Added support for 1227165 (1985-1986 TPI, 160 baud only).
Old Dec 19, 2001 | 02:53 PM
Jza's Avatar
Jza
Sweeeet! Now my other car is included!
Old Dec 21, 2001 | 10:10 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Jonas, what language is your program written in?
Has any thought been given to combine the work of the Moates program with yours to combine the high-speed data with a slick windows interface?
Old Dec 21, 2001 | 11:32 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
It is written in Visual Studio C++.
The 8192 data is not only faster, it is also a more complicated two way communication. WinALDL will probably not support the 8192 data format.
This is another scanner tool I found:
http://www.starrperformance.com.au/efilivev4/
It is a windows software for 8192 baud ALDL.
One good thing with this software is that it uses XML files to configure the display and to describe the ALDL data. XML is just a text-file so new definitions can be added without modification of the software itself. Some definitions:
http://www.starrperformance.com.au/e.../xml/index.htm
/ Jonas
Old Dec 24, 2001 | 02:57 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Unfortunately, it's $280 (US). That's not chicken feed. I was thinking that since your tool is free and so is Craig's that there would be a way to combine the two. Maybe I'll take a look this week since I'm off work...
--andrew
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
