89 Chip in a 88?
Old Dec 13, 2001 | 08:26 PM
JR4444's Avatar
89 Chip in a 88?
Alittle of topic but no tach board right now.....Will an aftermarket chip for an 89 350 Work on a 88 350? I don't think they changed anything major from 88 to 89 (Just Duel Cats) So it should work right??? Thanks
[This message has been edited by JR4444 (edited December 13, 2001).]
Old Dec 13, 2001 | 10:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You need to physically disable the Cold Start Injector, but the 89 code works in 86-88s. Many guys with MAF 165s burn the 89 ARAP BIN onto their eproms on 86-88s.
Old Dec 13, 2001 | 10:58 PM
JR4444's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
You need to physically disable the Cold Start Injector, </font>
Any suggestions on how to do that? Why is it nessary to remove the injetor?
Old Dec 14, 2001 | 01:17 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
You need to physically disable the Cold Start Injector, but the 89 code works in 86-88s. Many guys with MAF 165s burn the 89 ARAP BIN onto their eproms on 86-88s.</font>
Why do you have to disable the cold start if the 89 code has no referance to it? I'm running the arap, modified in my GTA with the cold start hooked up. Don't have any problems, it cranks on the 2nd turn of the engine. When cold or hot.
87 GTA 355/700r4
ported&polished 083 heads
xe268h comp cam
1 5/8 blackjack alumicote
homebuilt y pipe,pasesetter 3in mandrel cat back.
ported/manifold,upper plentum, tpis maf.
airfoil, 24# svo injectors, home programed chip, underdrive pulleys, erson roller rockers, chromemolley pushrods,2100 stall, shiftkit, 373 10 bolt.
Old Dec 14, 2001 | 02:28 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
[quote]<font face="Verdana, Arial" size="2">Originally posted by cp87GTA:
[b]
</font>
The cold start injector doesn't work through the ECM. It has its own independent circuit. If it is enabled and your car starts well, that's fine. But, the '89 code and a cold start injector are both richening the engine on cold starts.
It can be unplugged, or removed and the hole plugged. It wouldn't matter.
Also, be sure the '89 code has VATS removed unless you have the hardware for it in your car. An '88 Vet Hypertech chip came either way. I bought a used one a long time ago and couldn't use it until I got a VATS module off Ebay.
_ ___ _
SMasterson
[This message has been edited by SMasterson (edited December 14, 2001).]
Old Dec 14, 2001 | 04:51 PM
JR4444's Avatar
b
Old Dec 14, 2001 | 04:56 PM
JR4444's Avatar
The chip is from a GTA so it has VATS. So my options are
Get a VATS module
Remove it from the chip
What exactly is required when you get a VATS Module? Or How do you remove it from the chip?
Just to make sure the VATS is the little chip thing on the ignition key, right?
Old Dec 14, 2001 | 08:46 PM
Car: Death Mobile
Engine: 666 c.i.
You could just disable the "VATS" switch in the BIN. Takes a second to do and it's part of the 6E TDF from TunerCat.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
