Simple (er... I think) cooling fan question.....
Old Nov 7, 2006 | 12:11 PM
kevosiroc's Avatar
OK, so I modified the cooling fan enable and disable temperatures to correspond with the 180 degree t-stat I have.
I was refilling the coolant after replacing a faulty T-stat and noticed when the engine was really hot (240 degrees F) only one fan was on. So I rechecked my on and off temperatures and they were OK. So I thought maybe a faulty relay, bad wiring, or bad fan motor..... A quick check to see if the relay was working (and also the wiring) is to place the vehicle computer into diagnostic mode (ie place a paper clip into A and B terminals of the ALDL)... and.... both fans came on??!!??!!??
So, knowing the fans were able to be commanded on via diagnostic mode, that means that the ECM can command both fans on. So I re-rechecked my fan temp settings and they are primary on at 190 F and off at 180 F, secondary on at 200F and off at 190 F.
1. .....so what am I missing? Why weren't both fans on at 240F??
2. Via diagnostic mode, the the fans are commanded on via the ECM, correct??
3. could the ECM be bad? if so, why would diagnostic mode turn both fans on ... if the ECM controls them?
I am running $8D in a 7730 ECM (1990 Corvette)
Old Nov 7, 2006 | 01:28 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
The secondary fan that's controlled by the 7730 ECM is very rare. Your secondary fan is controlled by a temp switch located in the passanger side head. Here is an old post:
https://www.thirdgen.org/forums/diy-...nd+fan+control
Here's how to control the secondary fan with the 7730 ECM.
https://www.thirdgen.org/forums/dfi-...n-control.html
https://www.thirdgen.org/forums/diy-...ry+cooling+fan
Last edited by Jekyll & Hyde; Nov 7, 2006 at 01:32 PM. Reason: Automerged Doublepost
Old Nov 7, 2006 | 02:44 PM
kevosiroc's Avatar
OK, you got me, I am using a 7727 ECM. Even if I was not, does the 730 ECM actuate both cooling fas when in diagnostics mode? I do not see how it could if it is not wired to the ECM. If so, how?
Knowing that my cooling fans both come on when the ECM goes into diagnostic mode indicates to me that the ECM can control both fans. It is the secondary fan that is not coming on when in normal driving mode......
Old Nov 7, 2006 | 03:21 PM
kevosiroc's Avatar
here is the fan wiring diagram for my 1990 Corvette
File Type: pdf
Old Nov 7, 2006 | 03:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you swapped to a LS1, the PCM controls both fans with both temp and speed variables.
Old Nov 7, 2006 | 04:25 PM
kevosiroc's Avatar
Why would you think I swapped to an LS1?
Old Nov 7, 2006 | 04:26 PM
That I'm not sure about. I would guess that it's just a safety precaution that enables both fans through the relays. I think that the 7727 has the ability to control the secondary fan, just like the 7730, however, I'm not 100%.
Old Nov 7, 2006 | 07:32 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
From my notes on this:
Fan 2 request
727 730
"D21" "D12" pin
Fan 2 output
727 730
"A3" "F8"
A/C request switch
727 730
"B15" "D3"
Turned on/off by 4004, bit 1 (Port 41)
Old Nov 7, 2006 | 08:30 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
Could it be that your CTS is faulty and telling your ECM the engine is cooler than it really is. Anyway just a thought. I have my 91 730 wired like the vette and it works fine. Is there a min speed enabled or just the max speed disabled?
HTH,
Pac J
May 17, 2020 10:44 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
mfp189
Sep 27, 2015 09:25 AM
