erratic behavior with autoprom?
Old Dec 18, 2006 | 01:46 PM
devilfish's Avatar
Hi
Just started up my new freshbuild engine with the autoprom connected, using tunercat and datamaster to get the tune right.
BUT sometimes ( erratic ) the idle goes down and the SES light comes on just for 4-5sec, then its back to normal, and ses light goes off.
Anyone experinense this with the autoprom?
One other thought is bad ground somewhere. But will that make the fault be so erratic?
Thanks for your time.
Old Dec 18, 2006 | 02:02 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Plug a chip in and see if the problem persists. If so, a bad ground sounds reasonable. Or an intermittent sensor, etc. Does a code persist when this happens?
Old Dec 18, 2006 | 05:05 PM
devilfish's Avatar
Thanks for the fast answer. Yes i will test with a chip. No, unfortunately no codes get stored. The SES light flicker and the rpm drops, perhaps the flickering of the SES is to fast to let the ECM store the code? I dunno.
I does "feel" likes the ECM is more stabel when I use the autoprom but NOT scan it vs when i use datamaster to scan.
( sorry for the bad english ).
Regards
Old Dec 19, 2006 | 12:22 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
The flickering light could be where it is actually stalling and then catching itself and restarting. I've seen that happen before. That would also not set a check engine code since there was no error to report.
And your English is fine! I'm actually impressed with it. And it is on H3LL of a lot better than my Swedish!
Old Dec 19, 2006 | 02:32 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Hi all
i have the exact problem with my Ostrich....with a chip, the car runs fine, with the ostrich, the SES flickers from time to time, engine cut out, Datamaster looses connection, than catches up....
i think, the cable, that runs from the Ostrich to the chip pick up some RF noises from the ignition...
i tried to wrap it with aluminium foil, even grounded it, but that didntr help much...maybe a bit...
with in-car ECM the Ostrich works real fine...
Old Dec 19, 2006 | 04:24 PM
devilfish's Avatar
Thanks m8 Sometimes it can be hard to express your self in a foreign language.
Im not following you complete when you say "The flickering light could be where it is actually stalling and then catching itself and restarting". Why would the car do that? Does the ECM restart it self when something isent right?
Originally Posted by 396V8
Hi all
Thats the EXACT probleme I have. I havent tried a chip yet ( still waiting for my 259c chip to arrive ), and i dont whant o run this car with the stock chip
Old Dec 19, 2006 | 04:37 PM
vernw's Avatar
I meant that the idle may be dropping low enough that the engine dies briefly but the rpm's are high enough that the it restarts since their is still fuel flowing. Kind of like when you pop the clutch on a rolling car how the motor will usually start if the car is rolling fast enough. Just a long shot, but might be worth looking into a little more... How low are the rpm's when this happens?
Old Dec 20, 2006 | 12:12 PM
devilfish's Avatar
The rpm is at idle, around 800rpm just where I set it in the prom.
Then the rpm starts to drop and the SES light comes on. The car almsot die, then the SES light goes off and the car goes up to the desire idel rpm ( 800 ).
Old Dec 31, 2006 | 11:32 AM
vernw's Avatar
Any update on this? I was hoping some of the gurus would offer some advice and I might learn a bit more on this DIY stuff. Sorry I couldn't offer additional help, but it looks like you're beyond my level of knowledge....
Old Jan 1, 2007 | 02:06 PM
devilfish's Avatar
Hi
Well i havent got a change to do anymore testing. I wait for a new TB to be installed, and a new IAC.
What have done is to doubel check the grounding. I will let you know how i goes m8.
tmellott89
Oct 14, 2015 02:06 PM
thejimsterz28
Sep 30, 2015 08:52 PM
ironbmt
Sep 27, 2015 06:00 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
