Can This Be Done? (noob)
Old Dec 19, 2006 | 06:32 PM
supergumby's Avatar
I have just finished installing a 350 K motor with a 1227747 ECM (ASDU PROM) into my Astro Van, and it runs great.
I don't want to change the fueling, but I would like to add an electric fan output.
Is this possible w/ PROM editing?
Thanks.
Old Dec 19, 2006 | 06:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thanks.
Talk to RBob. You might be able to add an electric fan if you eliminate the EGR code and do some creative demolition and reconstruction in the ECM code.
Old Dec 19, 2006 | 06:57 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I did a 350 TBI swap in my old Astro, and used a 85 or so Camaro fan sensor that screws in head, and wired through a relay.
The switches come in different temps if my memory serves me right. It's been 6 years.
It's got 85000 trouble-free miles now, and a really great swap. The stock 350 carries the Astro up a grade with no slack at all, and still gets 17-18 mpg on road.
Old Dec 19, 2006 | 07:01 PM
supergumby's Avatar
Thanks for the quick replies.
Scuzz, that's exactly what I've done, but I don't like the 225 degree on temp. I was hoping to be able to use the ECM, and trim the temp to somewhere around 215.
Old Dec 19, 2006 | 08:00 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have been using a 2.8 Camaro fan switch in my 60* V6 TBI S15 Jimmy for some time. The fan is also run through an A/C pressure switch on the back of compressor. The fans come on at like 210* or 200 PSI.
Old Dec 19, 2006 | 08:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Then use a sender out of 87 Buick Grand National.
Old Dec 20, 2006 | 12:16 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Strangeness on an 87 Grand National
edit. sorry...
Old Dec 20, 2006 | 03:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The ECM cant be used for fan control without substantial mods. Youd have to disable the internal ROM and reprogram it. EBL can do this, but it may be easier just to use a stand alone fan controller of some sort, or a different switch.
Old Dec 22, 2006 | 05:08 PM
supergumby's Avatar
Thanks for the good info. I think Ill stay with a temp switch in the head.
Thanks again.
SonWolve
Convertibles
24
Mar 1, 2006 08:32 AM
Randy92Z
Sep 6, 2004 11:54 AM
cormyr
Aug 10, 2004 11:00 PM
ajbutowicz
Jul 2, 2004 04:15 PM
