problems with beginner tuning?
Old Dec 22, 2006 | 10:52 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im going to attempt to burn my own prom...am I going to have problems when trying to get everything in proper working order due to me using a 3400 stall converter from the get go? This is on a new engine that hasnet even beeen cranked. WIll the 3400 create problems when trying to get the off idle performance?
Old Dec 22, 2006 | 10:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
What software are you planning on using for editing, and what equipment for chip burning?.
Old Dec 22, 2006 | 10:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not really. Your engine will be less sensitive to changes at low rpm and low loads. With a nice cam and heads, you will not be using the lower load cells much. With my 2,800 RPM converter in my Van when I had the 312, almost the second I left the line, I was above 3,000. All the way through the gears it stayed at more than 3,500. It would go 750 to 3,000 up to 6,500, shift, down to 3,500, up to 6,500, shift, down to 4,000 rpm, back to 5,000+ I was trapping at 95-96 MPH in a 5,300 lbs Fullsize Van with a NA 305.
Old Dec 28, 2006 | 12:43 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I'm glad to see that you have decided to get into eprom burning. Unfortunately, I am having some "internet problems" today so I cannot help zero you in on some chapters to read.
But do read the first part of this link https://www.thirdgen.org/forums/diy-...uide-book.html
to see various writeups on:
1) bin editors
2) scanners
3) burners
The above is the equipment and software you will need to burn. There are a variety of opinions of which is better, so I won't go there.
fasteddi
Sep 2, 2015 10:29 AM
nuggie
Aug 25, 2015 01:27 PM
bdads
Aug 24, 2015 06:01 PM
soarestransam
Aug 24, 2015 08:15 AM
zeitghaist
Aug 18, 2015 07:33 AM
