EBL Dump File header explination
Old Feb 11, 2007 | 06:54 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Hey all, this is a dumb question this far in the game, but I still don't know what every one of the acronyms in the EBL's dump file mean. I could be missing some stuff to help me tune hear becuase I don't know what I am looking at. Maybe we can make a chart and sticky it in the beginning of the EBL post? Or just have a nice .doc use less experianced users can D/L and save for reference? Thanks again.
Old Feb 12, 2007 | 07:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This is something that is long overdue. I'll put something together soon.
RBob.
Old Feb 12, 2007 | 10:41 AM
liquidh8's Avatar
Transmission: 2004R
O ok cool. I appreciate it. I'm sure alot of us could use it.
Old Feb 14, 2007 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here are the current columns available in the .EBL dump file. Older versions of the WUD will be missing some of these columns (namely VAC & BRO, maybe Fpsi). Updates for the BIN & WUD are available to EBL owners ( at least for the life of the product).
Code:
RUNTIME	Hours:minutes:Seconds of engine run time. This is from the ECM
RPM   	Engine speed
MPH  	Vehicle speed
MAP  	Manifold Absolute Pressure in KiloPascals (KPa)
BRO  	Barometric pressure in KiloPascals (KPa)
VAC  	Manifold vacuum in KiloPascals (KPa) (this is barometric minus MAP)
VE%  	Volumetric Efficiency, from BIN calibration
TPS  	Throttle Position Sensor in % (0 - 100%)
CTS  	Coolant Temperature Sensor in degrees F or C. Selected in preferences
IAT  	Intake Air Temperature in degrees F or C. Selected in preferences
I/C  	Blended value of IAT and CTS, used for fueling calculation
O2  	Oxygen sensor value in milli-volts (450 mV is basically stoich)
G/S  	Grams per Second of airflow. Calculated by the ECM
SA  	Spark Advance in degrees BTDC
KnkCt  	Knock Count
sPW  	Synchronous injector Pulse Width in mill-seconds
aPW  	Asynchronous injector pPulse Width in milli-seconds
DC%  	Injector Duty Cycle in percent. Sync or async, which ever is active
Flags: shows a 'Y' when active, 'N' when inactive
AyAeDeIdPeDcClLnFnTcCpEg
Ay  Asynchronous injection active
Ae  Acceleration Enrichment active
De  Deceleration Enleanment active
Id  In idle mode
Pe  Power Enrichment (WOT) mode active
Dc  Decel Fuel Cutoff (DFCO) mode active
Cl  Closed loop mode active
Ln  BLM learn mode active
Fn  Fan on active
Tc  Torque convertor clutch (TCC) engaged
Cp  Charcoal Cannister Purge (CCP) active
Eg  Exhaust gas recirculation (EGR) active
Cl  	Cell, which BLM cell is in use (0-2)
INT  	Integrator, 128 is neutral
BLM  	Block Learn Multiplier, 128 is neutral
BPC  	Base Pulse Constant, ratio of injector flow to engine displacement
IAC  	Idle Air Controller in steps (0 is closed)
Fpsi  	Fuel pressure in psi. For Autometer 0-100 psi fuel pressure transducer
AFR  	Desired Air Fuel Ratio. ECM internal value
WB  	Wide Band AFR as reported from external device
dTPS  	Delta TPS % for Acceleration Enrichment (AE)
tpsAE  	AE pulse width from delta TPS%
dMAP  	Delta MAP value for Acceleration Enrichment (AE)
mapAE	AE pulse width from delta MAP
aePW	Final AE Pulse Width (compensated for CTS & RPM)
RBob.
Old Feb 14, 2007 | 10:05 AM
liquidh8's Avatar
Transmission: 2004R
Awesome! Thanks Bob. I have a question, what is the BLM cells?? 0, 1, 2 ?? How do you edit them? I'll have to search around and see if I can learn what that is. That is new to me.
Old Feb 14, 2007 | 11:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The BLM cells are: 0 is idle, 1 is cruise, and 2 is decel (throttle closed and not in idle).
By edit, you can change the thresholds that the ECM uses to decide which cell to use. The cell value itself is the long trim fuel trim.
RBob.
Old Feb 15, 2007 | 06:26 PM
liquidh8's Avatar
Transmission: 2004R
Ok, thanx Bob. I appreciate it. I am gonna keep this in my EBL folder for future use. Eventually I'll remember what they all are off the top of my head. haha
Old Aug 27, 2007 | 08:09 PM
Bones232's Avatar
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
Re: EBL Dump File header explination
RBob.
Could you possibly elaborate on this? When I'm idling the Cl will bounce between 0 and 2.
Old Aug 28, 2007 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Probably the RPM threshold for idle vs deceleration. Check this one:
BLM - Idle Cell RPM Threshold
Basically, if the throttle is closed it will use cell 0 or 2. When the RPM is above the Idle Cell Threshold it uses cell 2 (decel). Otherwise it will use cell 0 (idle).
If the throttle is open cell 1 (cruise) will be used.
RBob.
Old Aug 28, 2007 | 10:06 AM
Bones232's Avatar
Car: 1991 Camaro RS
Excellent. That explains quite a bit. Thank you.
Old Jun 13, 2019 | 03:09 PM
liquidh8's Avatar
Transmission: 2004R
so revisiting this thread, the EBL SFI-6 has addition headers, like F1, F2, etc. Could you shine some light on all the additional headers?
Also, is there a way to tell from a log when the second pump is running?
Thank you!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Chad Speier
Sep 24, 2015 12:32 PM
92rsvortec350
Sep 16, 2015 09:12 AM
hdis2002
Sep 8, 2015 02:52 PM
85Special
Sep 3, 2015 04:21 PM
