730 or 749 ECM for TPI ProCharger?
Old Feb 27, 2007 | 09:01 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have a 91 5.0 TPI 5 speed... The much later plan, when the motor dies is to get an ATI Procharger, etc...
I have the 730 Ecm and wanted to ad the nvsram upgrade to tune it...
I understand that the 749 ecm is for turbo cars... is it necessary for a supercharged car with proper ecm tune, proper fuel injectors (no fmu), etc...??
Raf
Old Feb 28, 2007 | 12:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You could use your old 730ECM just repinn som wires and load a $58code bin in it (from a Syclone with 749ECM) and start tuning.
The only reason to swap to a 749 is if you plan to modifiy it for P/H injectors.
/N.
Old Feb 28, 2007 | 07:58 AM
luvofjah's Avatar
So I don't need to purchase a 749, my 730 an be modified physically and with a different ecm program and "become" and 749 ecm?
"The only reason to swap to a 749 is if you plan to modifiy it for P/H injectors."
What is a P/H Injector?
I was just wondering, I know that the basic procharger systems have an FMU which boost the fuel when pressure is increased (more air, more fuel), so I thought that if new bigger injectors were provided and the correct mapping for air / fuel, I wouldn't need the ecm to monitor boost... ??
Raf
Old Feb 28, 2007 | 08:58 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Just a heads up - if you go the $58 code route, it is not yet supported by that nvsram module (though other folks are working on it).
You might want to consider Moate's osterich unit instead if your long term plan is to go boosted and switch to the other code base.
Mind you, if your plan is to just live with an FMU to deal with the boost, then you can use the nvsram module and keep your existing ECM and code base.
Old Feb 28, 2007 | 08:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Forget the 730, and 749,
go with the EBL.
It's got the proper coding for what you want to do, as is.
Old Feb 28, 2007 | 08:40 PM
luvofjah's Avatar
You'll have to forgive my lack of knowledge, but please EBaLorate on EBL...
Raf
Old Mar 1, 2007 | 12:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
...or sit tight for a while and wait untill 2bar 8D will be released.....
Grumpy: are you abandon the $58 code now?
/N.
Have read alot about the EBL and it seem very nice, has anyone done the TPI -> EBL swap? and headsup that I should know about?
Old Mar 1, 2007 | 07:03 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
is someone working on that? that would be awesome!
Old Mar 1, 2007 | 11:47 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Its done and its working ...... dont know if/when it will be released... We need to hold our thumbs!
/N.
Old Mar 2, 2007 | 08:22 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
it's done and working by a member on the board? i want to beta test!!
Old Mar 2, 2007 | 10:16 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
its already tested by he who did it.
Get in line for the "beta testing"
Hopefully he will release it this spring/summer, but who knows...........
/N.
Old Mar 2, 2007 | 11:12 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
you would think "he" who did it would help out other fellow thirdgenners and maybe even setup a donation for it.
Old Mar 2, 2007 | 02:34 PM
AC's Avatar
AC
Car: Used to drive a camaro
86Z and I would test for sure. I'm leaning on him to help me get my pig running with the 730 code. I gave up on even attempting to start with the &58.
stalkier
Dec 6, 2015 11:25 PM
355tpipickup
Aug 19, 2015 10:02 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
