Dual Prom Theory
Old Apr 7, 2007 | 10:17 AM
rustbird77's Avatar
Dual Prom Theory
I was trying to think of a way to run two seperate proms run to a switch on the dash so that you could switch between an economy burn, and all out performance burn.
I'm new to chip tuning (I havent even gotten the equipment yet, but I think this could work. I think that you can piggyback two flash chips on top of each other and solder all of the legs to each other except for the one that gets the 12 volt input. you would disconnect both of these from the zif connector, and run them to a switch. When the switch is pressed one way, one chip is used, when its pushed the other, the second chip is used. Here is a picture that illustrates what I am thinking
http://www.xbox100.com/tutorials/Tur...YourXboX_3.pdf
Scroll down to the picture of the two flash chips on top of each other.
You could also just wire a second ZIF connector to the underside of the ecm board. Or perhaps mount the connector for the prom remotely so that you could easily get to your chip. I just like the idea of having a switch with two seperate proms.
Let me know what you guys think, and how off I am.
Give me your guys thoughts on this.
Old Apr 7, 2007 | 10:35 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Dual Prom Theory
Check out moates
http://www.moates.net/product_info.p...products_id=86
He has a G2X TBI-Type Switching Adapter [Model: G2X]
Old Apr 7, 2007 | 10:38 AM
rustbird77's Avatar
Thats nice, but I"m operating TPI, that says only TBI. Thats similar to what I want to do though. Are there any solutions for TPI? I think soldering would work as long as someone had a pinout availalbe so you know what pin to switch.
Old Apr 7, 2007 | 10:45 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Couple of thoughts.
1.) Unnecessary, the Power and cruise areas of your program are in different regions. You can tune the cruise and other non-WOT areas for all the economy you want and tune the WOT for all out power.
2.) No need for separate chips, several programs fit on the same chip.
3.) Craig Motes makes a device to switch between different programs written to the same chip.
or
G3 Bank Switching Adapter
Enjoy
Old Apr 7, 2007 | 10:53 AM
rustbird77's Avatar
Ok, thanks for the input. I am new to this, and have a lot of research to do.
Will the burning equipment work the same between a TBI and TPI. I was talking to a guy about buying his equipment that he used on a TBI car.
Old Apr 7, 2007 | 03:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Instead of switching power, there is a chip select (CS) input to the PROM. Grounding that line will select that chip. You do need to power both chips (to +5v) as the data and address lines are connected.
Place a pull up on PROM's CS line, then set your switch to ground one or the other. Flipping the switch with the engine running will most likely result in an ECM reset (engine skips for a half a second). So no flip of the switch while at WOT
RBob.
Old Apr 7, 2007 | 06:26 PM
jms's Avatar
jms
Check out this thread
https://www.thirdgen.org/forums/diy-...rominator.html
I've been running a Prominator over a year and had absolutely no problems.
Eight programs to choose from with the turn of a ****.
Using TunerPro for the software and an old laptop to upload programs.
jms
Old Apr 15, 2007 | 07:46 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
jms
Do you think the prominator would work good with the bottle. I am looking for a way to have two tunes. That way I can have one for the bottle with less timing and one for n/a with more timing. I want to do this with just a flip of a switch.
Old Apr 15, 2007 | 08:31 PM
jms's Avatar
jms
Have you read the thread mentioned?
I am far from being the person to answer your specific questions, however, the 8-bin switch "should" allow what you want. What programs you place in the different positions is up to you.
jms
Old Apr 15, 2007 | 10:52 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
jms
I am sorry. I am new to this. I have been looking into the prominator thread. It sounds like thats what I need.
Linson
Oct 24, 2025 02:00 PM
zman1969
Oct 1, 2015 11:09 AM
