Dyno numbers for the truck
Old May 22, 2007 | 08:48 PM
91chevz71's Avatar
263.1 hp, 308 ft lbs.
considering a 20% loss for drivetrain, that's not too bad.
Seems like there should be more, but I talked with the guys at the shop and they think running big tires (35) on 16 inch wheels are dragging me down. I have 4.56 gears in a 9.5 inch 14 bolt SF axle which is probably sapping a few more HP/TQ than your average truck 10-bolt.
I actually made a few changes to the VE table during 2 hours of test runs- the AFR held at 13.0 in PE from 2000 rpm and up.
Played with injector offset- no changes. TUrned Async on- no change. The only Async fuel I get is Async AE when I floor it, that's it. My injectors reach about 86 percent DC at peak. I reduced PE SA by 1.5 degrees and gained 5 HP at 5000 rpm. Fuel pressure was at 15 psi according to the dyno (had the line plumbed in) which contradicts my fuel pressure gauge (14 psi). I thought my fuel pump was going out- not the case. 15 psi SOLID though the entire RPM range.
I feel like the tune is pretty good, but it seems like I should be getting more power.
The 350 HO was dyno'd by GM to have 330HP and 380TQ.
-edit GM numbers were on a stand (obviously) with a carb, and probably a high rpm manifold
I think maybe porting the manifold and heads with a good port job will help out.
Whaddya guys think?
Old May 22, 2007 | 09:02 PM
91chevz71's Avatar
Re: Dyno numbers for the truck
seems like I should have more torque.
I think air/fuel delivery is robbing me. I have longtube headers each feeding their own cat then going into a dual in dual out muffler (all 2.5 dia pipe)
I bet the porting will unlock some more power
need a roller cam too. I want the ZZ4 (thanks Fast)
O yeah-
had some knock at 3K rpm, and 4K. pulled 1 deg in those areas, and pulled some from PE SA (like I said)
Old May 22, 2007 | 09:04 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
20% loss on 330hp is 264hp.
20% loss on 380trq is 304trq.
Looks like you are right where you should be?
Old May 22, 2007 | 09:12 PM
91chevz71's Avatar
It just feels slow.
I need money for a cam change and port job.
Fast305's van would smoke my truck. I need a new cam...lol
must...get...more...cash
Old May 22, 2007 | 10:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Originally Posted by 91chevz71
It just feels slow.
Your driving an urban assault vehicle. All that steel really loads the motor up good.
Old May 22, 2007 | 10:33 PM
91chevz71's Avatar
yeah...power is addictive, though.
I kinda want an old beat up camaro to build up
Old May 23, 2007 | 12:27 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Trade ya!
In all honesty, the crappy car thing gets old fast. Especially when the engine tears the car apart.
Old May 23, 2007 | 12:45 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
I'd say you did excellent for that motor, that drivetrain, the cats, the tbi.
Are those numbers corrected for altitude/weather?
I've heard of cars with more performance parts doing worse.
Old May 23, 2007 | 09:50 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yep...sounds like you are where you should be.
Old May 23, 2007 | 04:33 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
It just feels slow.
With those huge tires, your effective gear ratio is much worse than stock, so it will feel slow.... not matter what the engine is doing.
IOW a 4.56 rear end on 35" diameter tires is equivalent to a 3.51 ratio on 27" tires (225/70R15 size, as an example). You're giving up the potential acceleration performance of ther 4.56 by using huge tires. And a 3.51 rear end in a 5000 lb truck isn't going to feel as spry as it would in a 3500 lb Fcar.
Those two things together are what is making the truck feel slow.
Pay close attention to some of the things he's done. You don't want to swamp what you have with too-large-a-cam and lack of tuning.
Old May 24, 2007 | 08:44 PM
91chevz71's Avatar
Yeah, the numbers are correct for the environment.
What close things? i'm curious
High FP with small inj?
roller cam?
high stall?
what else?
Springster
Sep 13, 2015 01:38 PM
Doobie52
Sep 11, 2015 06:19 PM
Amillionoh7
Sep 11, 2015 11:36 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
