BLM/INT???
BLM/INT???
Just a dumb newbie question but what are the differences between tuning with the blm or int?? I borrowed the scanner from work to do some primitive tuning and it does not have a reading for blm just int. So im trying to do some ve tuning by getting someone else to drive while I read and write down some info. Im only able to see the int value's as well as map/o2/coolant temp/tps/rpm and speed. Im just wondering if there is a different calculation used for int campared to blm before I mess up my ve tables?? Greatly appreciate any help.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: BLM/INT???
i've used the Mac version of it.
it should show the BLM, look for long term fuel trim
bataradena
Jan 11, 2008 10:17 AM
