Ve's good/less power???
Old Jul 4, 2007 | 09:29 PM
90c350's Avatar
Ok so now I have my Ve tables within 4to5 +- of 128 and Im am down on power?? I have a bit of a surge at certian rpm and a lean pop on accell. I know how to fix the accel pop, but where did my power go??? Should i try running in open loop?? Also wondering how to attach a copy of my bin so that someone with more experiance can look at it?? Sorry for all the questions but Im getting somewhere now, Please help. Thanks
Old Jul 4, 2007 | 10:34 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Ve's good/less power???
i think its going to be in your timing.
you said in your other post that timing is as low as 13 in some areas, & no higher than 29 in others.
in my bin, my lowest timing is 19, highest is 40.
a few degrees can make a huge difference in performance.
i was fighting was some ping, 1100~1200 RPM, 80~90 map, i pulled the timing from around 22 to 16, it cause a noticeable loss of power. i could feel the car stop pulling in that area.
i think you need to zip the bin to post it.
also, you would need to post a data log with it.
Old Jul 4, 2007 | 10:38 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Well, what are you running in that 350
give us some more info on what you have
Old Jul 4, 2007 | 11:30 PM
91chevz71's Avatar
I have noticed loss of power with reduced timing also, that's to be expected I would think.
I also noticed a loss of power when my BLM/INT numbers were 128 +/- 5, but when I was running a a tad more rich I had more power.
14.7 AFR is the best for emissions, so it makes sense that a slighty rich average of BLM would make more power.
I have changed my stoich closed loop AFR to 14.3 and tuned my VE table with my wideband (targeting 14.7) then added 1% VE to everything (shooting form the hip) to try and get it to 14.3. I haven't messed with my chip for about a month, but now that it's really hot outside I'm gonna get back into it.
Old Jul 4, 2007 | 11:44 PM
90c350's Avatar
Hey thanks alot guys thats great info as usual. I have just realized that if I use a different xdf there is a fair amount more timing in it. So tomorrow Im going to try that one with my curent ve's and see what happens. As for the 350 is a stock bottom end 4bolt./ 8.5.1 compression/461 heads/comp Xe256 cam/ 212int/218exh duration @.5lift/110lsa/447.454 lift/Ceramic shorty headers/Edelbrock Air-gap rpm manifold/61lbs injectors at 20 psi-113bpw/Afpr-jet/Msd coil and wires/ultimate tbi mods. That should cover it I think. Thanks again guys and Ill let you know how the xdf/timing change works.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
