Help Please
Old Jul 15, 2007 | 11:05 AM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Help Please
i need help; im totally lost. my setup:
87 S10, with 350 running on 88 '165. its from a 305 but i can't remember what bin. i know that this isn't the best setup, but its all i had at the time.
heres my problem. i can't get into diagnostic mode. i've checked all my connections about 8 times, using a test light and DVM. everything seems good. wiring for the SES light is good. i jump the ALDL, and there is only a steady SES. this is driving me nuts because i keep getting the SES light on the highway, and i can't figure out whats wrong. which leads to my next issue...this damned light! it comes on at about 65mph, and goes out under 50mph. i cut and removed wiring for AIR, and canister purge, could this be my problem?
i plan to buy a moates adapter and all the other stuff so that i can get the correct 350 bin, and hopefully run better. thanks for any help that you guys might be able to provide, Jim.
Old Jul 19, 2007 | 04:05 PM
87 Vette Owner's Avatar
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
Re: Help Please
I recommend getting a good & correct 350 bin in there before you start chasing the SES light / diagnostic issue.
Old Jul 19, 2007 | 06:55 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Help Please
S105.7
Regarding EPROM (bin file)
You can get a good idea what your BC code you are running by taking EPROM out of ECM and reading contents with EPROM reader-writer. Once you have an image file a binary compare can be done with TP (or other program) against know good '165 bin files. You can find a list of image files for '165 on DIY EFI:
http://www.diy-efi.org/gmecm/ecm_info/1227165/
With respect to ALDL - can you data log with WinALDL or similar program? You may have bad ECM interface - which looks OK externally (i.e. connector to connector is OK, but ECM never sees I/O line being pulled low for diagnostic).
I hope this helps
//RF
Old Jul 19, 2007 | 08:05 PM
S105.7's Avatar
Engine: L98 & L03
Re: Help Please
thanks for the replys.
i downloaded tunerpro tonight, and started playing with APYP. it seems like everyone goes right to ARAP, but with 10.5:1 and iron heads thats not going to happen. is this a bin you would recommend me starting with?
i played around with it a little tonight, mostly changing flags and constants. tunerpro makes it seem like childs play. for the moment, i have no hardware, or laptop. im working on getting that stuff real soon. im just getting started, and this was a big step for me to start messing around.
thanks for bearing with me, Jim.
Old Jul 19, 2007 | 10:18 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: Help Please
For a 305 running a manual tranny on a '165, use ANZA.
Old Jul 20, 2007 | 03:51 PM
S105.7's Avatar
Engine: L98 & L03
Re: Help Please
thanks, but im looking for a 350/700R4 bin.
Old Jul 20, 2007 | 09:24 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: Help Please
AUJM is the newest firebird 350 700R4 with 3.27 rear. It's $6E, so disconnect the cold start injector if you program that. Use this - assuming you're using an F-body wire harness, and 86-89 MAF sensor. Also, you'd have to change the injector constants to whatever injectors you're using. If you have 350 injectors already, then no need. If you get a programmer, then you really don't need to find the right chip at all - just make your own.
The speed based diagnostics could be EGR, but it's hard to say. It's a good idea to find a spare ECU, anyway, and it would help you diagnose your problem. Converting to a '730 ECU also isn't too hard, so they say, and would give you a more reliable ECU (IMO).
You could take your car to most car parts stores to get a free code scan as well, if you want to test your setup for communication.
Old Jul 21, 2007 | 11:33 AM
S105.7's Avatar
Engine: L98 & L03
Re: Help Please
redngold, thanks for the reply.
yes, i am using an F-Body harness. its from an 88 Z28. will it be possible to change from the magnetic VSS to optical with the firebird bin?
as for the '730, i plan on doing that in the future. i already have the ecm, and im finishing up a harness. i plan on running $59, as i hope to have a MP T-70 under the hood before too long.
Old Jul 22, 2007 | 10:49 PM
Re: Help Please
I don't know much about the VSS input, sorry. You can try it and post your results! Or do some searching, I guess. I'm in the middle of a road test, and don't have time anytime soon.
