What chip to use in this situation? Engine & gearbox change
Old Jul 20, 2007 | 11:32 PM
IroczInOz's Avatar
Posting this on behalf of a friend. The finishing touches are being done as we speak on his new engine and gearbox setup. He has got a 1990 IROC that has now a new 383 crate engine with HSR + 6 speed gearbox.
It needs a good tune now. The car started was a bit rough at idle most likely due to the INJ constant 24 while it has 32lbs. The guys are gonna put it on the dyno and dial it in. But my mate is not sure what chip option is best. He has ostrich and uses tunerpro..
But the question is what chip should he be using for best results?
SAUJP? That is what is currently in the car
or
Vette chip that came out in 6 speed vettes.
Is there anything majorly wrong with running a SAUJP in a manual car? The only thing that I can think of is the VSS which will have to be hooked up so the ECM knows speed.
What is the best way to go guys?
BTW engine is a 383 crate engine 500hp, alloy heads...
Old Jul 21, 2007 | 01:41 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: What chip to use in this situation? Engine & gearbox change
Personal preference?
I would go with a vette bin, but IMHO I would use a TPI 305 setup speced with the appropriate changes as abetter starting point and alot safer timing table to start.
I dont like starting with scary looking timing tables like vette/firehawk/saujp all have in them. Most people who tune seriously end up having tables looking nothing like those when done(not hating on anything/one)
later
Jeremy
Old Jul 21, 2007 | 02:36 AM
IroczInOz's Avatar
later
Jeremy
I hear you! What I was thinking maybe is to use the Vette BIN and upload the stock 350 spark tables in and use them. The guys who did the engine swap and conversion to manual will put it on the dyno. They want to try and give it a nice tune while on dyno to see where they are at. So maybe use the Vette bin and copy over the spark table etc.. yet change the engine specs to match the new engine and take it from there.
I myself have never looked at a vette bin and am not sure what RPM the tables go to? I know the SAUJP tables have been tweaked and go into the 6000rpm range whiich was a benefit.
Thanks for the heads up. Do you have any recommendations on what Vette bin to start with? We need it to be MAP.
Old Jul 21, 2007 | 07:51 PM
IroczInOz's Avatar
3.8TransAm I think you might have given good advice. I have downloaded the AXXD 5spd F-body bin and will tell my mate to use that. We will change the relevant tables and constants to match his engine and then take it from there.
I have read a few people have done the same and used the 5spd f-body bin for their 6spd set-up.
So it looks like the go, plus the advantage of it being a mild bin to start off with. Maybe once SAUJP v4 comes along might be an option to change over and just copy over the values from the AXXD bin.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
