Tuning a built V6
Old Jul 27, 2007 | 02:07 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Tuning a built V6
Hey all, Coming to you guys for some advice... i'm using a '7730 ECM to run a V6 with a big cam, headers, port work etc. Been working on the tuning for a month or 2 and it was getting pretty close. then the fuel pump went out.
I replaced the pump with one for a stock 350TPI and a new filter.. then my BLM's dropped to 91
I'm using Freescan to datalog since tunerpro RT won't connect to the ALDL box.
Basically i know that i need to adjust the VE all over the place now but the oddity is the NB o2 volts when it goes into PE mode. I'm commanding a 12.3 AFR and the o2 volts are going way lean. They weren't doing this before the new pump...
BTW, i'm using #32 sy/ty injectors and a 43PSI FPR. (full mod list here: http://www.v6z24.com/registry/whitelightning2/ )
Here is a datalog: http://www.davesux.3x00.com/726chipLA1timing2.csv
thanks for any help!
Dave
Old Aug 8, 2007 | 12:35 PM
11sORbust's Avatar
Re: Tuning a built V6
Get a wideband 02, the NB is nearly useless at WOT(and idle sometimes). Your 1-2 months of tuning would have been cut in half. That alone makes it worth the money. Your trans am will also thank you. (-:
Old Aug 8, 2007 | 12:55 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I was getting between 170-250mV at wide open no matter what I did on my brother's v6. I changed the O2 sensor, and nothing else and started getting readings in the 950-1000mV range, I think it depends on the sensor quality and especially its condition.
from experience, a wide band is invaluable when making a good tune.
Old Aug 8, 2007 | 05:07 PM
Engine: 450HP 355
Transmission: TH350
got a wideband sitting right infront of me, just need to finish building the harness and it'll be reay to install. The car is up on jack stands for a few upgrades, hopefully next week i'll be able to test it out
The Trans Am? you mean that purple thing collecting dust on the side of my house?
Old Aug 8, 2007 | 07:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Exactly as 11s says. Both Tim, myself and almost all of us old time TGOers here have ALL been there...and we ALL have learnt that on a WB O2 is really the only way to get there. You MAY get it close (especially if you use it inconjunction with other old school tricks like reading plugs), but a WB is really the only effective way to do it.
Further, with Real Time tuning & a WB will make the job even faster yet. You'll do in days what takes months...and it will be done RIGHT!
But I am so glad to hear that you are installing a WB.
Old Aug 8, 2007 | 11:22 PM
Engine: 450HP 355
Transmission: TH350
Thanks!
I tuned the T/A the old school way, by smell/feel and it ran pretty good, only in the last 2 yrs got into this computer tuning.
I've been piecing together a WMS wideband unit, Should be done ASAP. I'll also be able to datalog with it through the ECM which will be a nice plus...
I might end up using it on the T/A down the road after i rebuild the engine.. probably gonna switch to EFI on it as well.
Old Aug 9, 2007 | 11:57 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Thata boy!
Old Aug 10, 2007 | 12:02 AM
Engine: 450HP 355
Transmission: TH350
Originally Posted by Six_Shooter
Thata boy!
oh you just wait till you see the plans...
Since it's a project with no deadline it's probably gonna get a set of spooly things.. If i can only find a good aftermarket EFI Vortech manifold..
Old Aug 15, 2007 | 10:35 PM
11sORbust's Avatar
You need to really learn that six banger stuff. I think it would be great to have an expert v6 guy here on the prom board.
Old Aug 15, 2007 | 10:44 PM
Engine: 450HP 355
Transmission: TH350
I got my ostrich 2.0 yesterday, haven't driven the car yet but i plan on hitting the tuning hard in the next few weeks...
fbodyfreakls1
Oct 6, 2015 06:34 PM
customblackbird
Oct 1, 2015 04:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
ericjon262
Sep 11, 2015 06:07 PM
