Upgraded engine, will stock bin get me by?
Hi all,
I was wondering if someone can tell me if my stock ($8D) bin will be able to (safely) run my new motor until i can get some logging/tuning time with it.
Here's the Engine specs:
Heads: Aluminum 180cc runner, 2.02/1.60 valves
Cam: Comp "xtreme energy" TPI roller cam, 276/290 deg. adv
220/230 @ .050
.547/.547" valve lift w/1.6 ratio
Injectors are 22lb/hr and ignition is stock as well, 2200 stall converter.
Sooooo, anyone know if my stock bin will run this setup ok until I can get some tuning done on my own? Thanks in advance.
220/230 @ .050
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: Upgraded engine, will stock bin get me by?
Very doubtful. Need to just start tuning it as soon as you fire it up.
Car: Death Mobile
Engine: 666 c.i.
Even the stock eprom on a stock engine can benefit from tuning - especially SD TPI engines (yours). While your engine should run with the stock eprom, it will be far from optimal. You will probably be short 30-40 HP from where it should be with a properly tuned.
However, an "off-the-shelf" or "mail-order" eprom will not get your those results at all.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My LT4 HOT cam engine ran eyes-burning-rich when I first started it, and I'm guessing your camshaft will run the same. You're going to need a custom chip to start it.
Thanks for all the replies. The last time I tried with another engine, it ran the "eyes burning" rich as mentioned here. I may have to play with the fuel tables a little at first, I just didn't want to until I had a few "break in" miles on the engine.
Car: Death Mobile
Engine: 666 c.i.
The O2 sensor does quite a bit to help correct while you are breaking it in AS LONG as you don't go WOT. Your idle will need help and you can do some datalogging & correcting while just "breaking it in".
But, WOT is where you will need the most help. Just get yourself a WB O2 sensor (which will be offset by not having to buy a custom eprom that will be a compromise at best...unless THEY are going to hook-up a WB O2 sensor for you).
NinjaNife
Aug 23, 2015 11:49 AM
