MEFI 4 definition files?
Old Aug 27, 2007 | 07:38 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
i was wondering if anyone has the defintion files for a Ramjet 350 with a mefi4 controller?
Thanks Jj
Old Nov 23, 2007 | 07:46 PM
70ss's Avatar
Re: MEFI 4 definition files?
I don't have the exact one, but probably something to work with.
Old Nov 24, 2007 | 01:24 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If I recall correctly, the following site has some TunerPro defs for MEFI:
http://www.obd2allinone.com/sc/toplevel.asp?cat=32
Old Jan 20, 2008 | 02:02 AM
87 Burb's Avatar
It looks like they've got them, but they've locked them away in a library for users of their products only. You've got to email their sales department with a request.
Looks like you could get one from MSD with their MEFI-4 offering, but again you need to buy their product. You can download the software for free and the RamJet 350 bin is in there, but you need the hardware key that comes with the purchased product to see it.
I'm running a RamJet 350 with a port modded EBL and would like to look at the factory RamJet spark table. Anybody have one? Mangus?
Old Jan 20, 2008 | 02:34 AM
91chevz71's Avatar
just run a stock vortec L31 table and go from there. should be pretty decent
Fast 305 posted this over at FSC
97 vortec 350 SA table
Old Jan 20, 2008 | 03:00 AM
87 Burb's Avatar
Good suggestion...as a matter of fact I am running the L31 spark table. Problem is, it hits the wall at 4000 rpm and the exhaust manifolds start glowing red - apparently not enough spark advance. When tuned properly, the RamJet 350 makes around 400 ft/lbs almost to 5000 rpm. I would really like to see the factory spark table...anyone?
Here's a dyno sheet from one of the magazine tests of a RamJet 350. A little higher than GM claims, but not much.
Old Jan 20, 2008 | 08:57 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would suggest the B-Car LT1 timing map.
Attached Thumbnails MEFI 4 definition files?-b-car-lt1-350
Old Jan 20, 2008 | 11:47 AM
87 Burb's Avatar
These would be the iron headed LT1s in the Impalas and Caprices? That's an interesting idea. If I understand the history of the Vortec heads correctly, Vortecs are basically the iron LT1 heads without reverse flow cooling.
I'm at 6600 ft. With the ignition on, engine not running, I see 80 kpa. Looking at the B-Car LT1 timing map at 80kpa (WOT for me) there is definitely more advance in these tables at 4000 rpm. If I can't find an actual RamJet spark table that takes into account the RamJet cam, this looks like a good starting point. Thanks!
Old Jan 20, 2008 | 11:49 AM
91chevz71's Avatar
I hear ya on the altitude. 83 KPA max for me
Old Jan 20, 2008 | 01:17 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Yes, the B-Car LT1 is the Iron Head LT1 which has the same chamber design as the Vortec and about 1 point more compression, but also reverse flow cooling. The cam in the Ramjet is very similar to the Vortec/B-car LT1.
Old Apr 22, 2008 | 01:54 PM
hrodgmc's Avatar
Pm me.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
