car will barely run now.
Old Sep 25, 2007 | 05:40 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I tried burning my own chip for the first time last night and didnt like the out come of the chip so I took it out and put the one back in that fast chips burned for me. Now the one fast chips burned was running smooth at idle and the chip I burned my self ended up barely able to run at all during idle, well actually idle was to high and then I would put it into drive and the rpms would drop and the car would barely run. So I put the the other chip back in that fast chips made and I am still getting the same problem, it will barley run at all now. I dont understand what is happing, I was going to use the chip that fast chip gave me as a back up just in case the chip that I burned myself didnt work out. Why is my orginal chip not working now?
Old Sep 25, 2007 | 06:18 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Re: car will barely run now.
What mods have you done? The first thing to check is are you installing the notch in the chip towards the outer edge of the memcal,not towards the middle.
Old Sep 25, 2007 | 07:02 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
My guess would be that the "learned" fueling was not cleared by removing power from the ECM after each file change was done.
Until you clear it out and then do a bit of relearning, it will be rough.
Unless of course the tune is really good.
Pull the battery cable or ECM power fuses and try again.
Might have to cruise it around a bit before it come back to normal.
Hopefully you haven't fouled plugs or something to make it that much worse at idle.
Old Sep 25, 2007 | 07:12 PM
Car: 91 Trans Am
Will I removed the battery cables for 30mins and tried it but it was still the same. I will try again and this time remove the ECM power fuses and see what happens.
My mods are ported heads, zz9 cam, headers, mini ram manifold, block bored .30 over with a compression of 9.5:1.
Old Sep 25, 2007 | 07:34 PM
Car: 91 Trans Am
I just check my timing and some how it moved to 8*. It was originally around 22* so I am thinking that if I advance the timing it should run fine.
Old Sep 25, 2007 | 07:47 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Your timing should match your chip setting. Look at your fast chip in tuner pro and set your timing to match. Any timing adjustment should be done in the bin file using tunerpro (or what ever program you use). Most stock chips are set at 6* timing.
Old Sep 25, 2007 | 08:26 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Sounds like it's running on just the module (i.e. base timing only), and not the chip.
Old Sep 26, 2007 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is a good possibility. JCL91, check for the SES blink at key-on, engine-off. It has to blink for it to be running from the PROM. This is a check that should be done each time the PROM is changed.
RBob.
Old Oct 2, 2007 | 12:12 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
i agree with Rbob sounds like you're running on the netres
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Reborn756
Sep 4, 2015 03:42 AM
kyleb24
Aug 15, 2015 08:24 AM
