Winaldl timing??
Old Sep 28, 2007 | 12:00 AM
90c350's Avatar
Winaldl timing??
Another quicky!! Is there any way to see if and how much timing the ecm is pulling out when dataloging?? I know it reads knocks and knock area. But can it also see the ecm adding or subtracting timing?? THanks again.
Old Sep 28, 2007 | 12:30 PM
Ronny's Avatar
Re: Winaldl timing??
the amount of knock retard is what ever is present in your .bin. you can change it to whatever you feel is appropriate. not sure what is in stock .bin but I will guess it is a few degrees and willl continue to remove till it does not repeat. you could zero it out but then you dont have that feature if you really need it.
In EBL you could see the "retard" sequence and amount as it logs SA
Old Oct 4, 2007 | 07:37 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
To make my tune easier I zero'd out the retard...It was way too confusing with it enabled. Enable it when your done...Thats my opinion anyways
Old Oct 5, 2007 | 07:28 AM
87 Vette Owner's Avatar
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
That's fine if you are sure the knock is false; a little dangerous if not.
Old Oct 5, 2007 | 06:16 PM
I agree somewhat... if your aware you have the retard disabled as you tune your timing you would most likely be looking for knock anyways...but yes, ignoring knock would be dangerous.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
