RPM Wrong?
Car: 88 GTA
Axle/Gears: 10 bolt rear w/3.73 richmond gears
RPM Wrong?
While doing some datalogging I noticed that my rpm guage (Digital Dash) reads about 600 rpm higher than the Tuner Pro RT reading. Which should I trust?
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: RPM Wrong?
My first instinct would be to trust the reading from tunerpro as stock tachs are notorious for being inaccurate. If you had a timing light with an rpm indicator it would be easy enough to check.
Car: check
Engine: check
Transmission: check
Re: RPM Wrong?
I'm with what rhuarc31 said. Check out this thread on the electronics board:
https://www.thirdgen.org/forums/elec...meter-fix.html
The one in the '92 also reads a bit high.
RBob.
RBob.
Transmission: 5-speed/T-5
Re: RPM Wrong?
All I had to read was digital dash and realized that it probably is the culprit here. Most digital dashes from GM are KNOWN to be hugly inaccurate AND problematic.
MikkoV
Sep 9, 2015 04:25 PM
