TPI swap with problems
Old Nov 6, 2007 | 12:40 PM
dsw12387's Avatar
I have been in the process of swapping TPI into a Nova and I am haveing a few problems. I fired the thing up last night and it ran decently well, seeing how most of the stuff came from a junkyard, but i am haveing a few problems. The car does not want to idle, it will run but it "hunts" for the idle and will almost die and bring the RPMs back up. I pulled the codes and this is what i got. 22,33,41,and 43. would anyone have a good place to start in diagnosing waht could be causeing my problem. Thanks
Old Nov 6, 2007 | 12:43 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TPI swap with problems
DSW
Need a bit more info -
1) which ECM are using and BCC?
2) is it SD or MAF setup?
3) Engine type, size, etc
//RF
Old Nov 6, 2007 | 02:06 PM
dsw12387's Avatar
sorry for the lack of info
1: iam using a 730 ecm with a vats delet
2: It is a SD setup
3: 350 cid engine with rebuild and factory roller cam
ONe more thing is this swap is being done with an aftermarket wiring harness.
Also the engine is not want to take the gas hardly. you give it gas and it takes for ever to respond and it will not rev very high either, i dont have a tach hooked up but i would say the most would be around 2500-3000 rpms. i havent really had a lot of time to mess with it either so i havent tried anything.
Old Nov 6, 2007 | 02:15 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Have you checked for vacuum leaks? What is your fuel pressure? What type of pump are you running?
Old Nov 6, 2007 | 02:25 PM
dsw12387's Avatar
I have checked for vaccum leaks and found some, before i posted this the thing would not even idle, but it is very possible that i have missed something. the fuel pump is an inline pump from Napa off of an older ford van. I am not sure about fuel pressure i dont have a gauge to check it with.
Old Nov 6, 2007 | 03:04 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
If it is an early 80s Ford van with sequential fuel injection you should be fine. If it is from a van with throttle body injection it is too small. TPI hates vacuum leaks. Go to Auto Zone and see if they have a fuel pressure guage you can rent.
Old Nov 7, 2007 | 09:36 PM
dsw12387's Avatar
Checked fuel pressure today and it is staying at a constant 45 psi. I will hopefully get a scan tool hooked to it tomorrow.
Old Nov 8, 2007 | 07:17 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Check all your mechanicals are good before going too much farther.
Reset TPS and IAC, try to locate vac leaks, timing set to 6* with bypass connector unplugged, fuel pressure is good etc.
One thing that came to mind when you said it wouldn't rev.
Are you sure you have a V8 memcal in the ECM?
customblackbird
Aug 15, 2021 10:16 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
