chip formating?
Old Nov 6, 2007 | 08:57 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
chip formating?
before i try to burn my first chip, do i need to format it or do anything other than selecting they type of chip in flash n' burn?
Old Nov 7, 2007 | 01:49 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: chip formating?
Formating is only neccessary for file systems, a chip like this contains only binary non-moving pre-determined fixed-position information and so needs only to be burnt straight in, no extra fuss.
Old Nov 7, 2007 | 09:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: chip formating?
If its a flash chip, then no, just plug it into the burner, select the right chip in the software, and burn it.
If its an EPROM chip with a window, then it should come blank, but after you burn it once, you will need a UV light eraser to blank it and use it again.
Old Nov 7, 2007 | 03:16 PM
88tpi350's Avatar
Car: 88 formula
Re: chip formating?
cool, thanks a bunch!
Old Nov 8, 2007 | 12:05 AM
90c350's Avatar
Re: chip formating?
It would be suggested that if you are using a flash chip and a burner that you do a blank check first and then go ahead and burn your program.
Old Nov 8, 2007 | 02:23 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: chip formating?
Some chips require an erase first, such as the 27SF512. UV-eraseable chips also require erasure before a new burn.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
Linson
Oct 1, 2015 09:50 PM
