BIN changes before starting new engine
Old Feb 16, 2008 | 01:47 AM
AUS-IROC's Avatar
Car: 1986 IROC Z
Engine: Nothing but air
Axle/Gears: Four stands
Hi guys I want some help getting my bin ready for when I start up my new engine. I have read, re-read and read again all the tuning articles and just want a check-list of things I should change before I fire up my engine.
I'm tuning with TunerPro RT and starting with a standard 89 camaro bin with the 6E.XDF. My engine is an L98 350 with GM HOT cam kit and Patriot alloy heads. The intake has a BBK throttle body, ported plenum, SLP runners and edelbrock manifold and Ford 24# injectors.
I know I will need to change my injector constant to suit my 24# injectors and disable VATS. What else should I change before I start up my motor?
Old Feb 16, 2008 | 12:46 PM
91L98Z28's Avatar
Car: Z28
Re: BIN changes before starting new engine
I'm assuming you are running headers and probably do not have a heated O2 sensor yet?
You might consider disabling closed loop (set the enable temp to 255) so that you don't have to deal with it right away when you're breaking in the new engine. The combo of cam + headers + non heated O2 might be just enough to start causing some (probably minor) issues.
You might also consider bringing the idle speeds up a bit, 6E has idle speeds down to 600 IIRC whereas the HOT cam might want to be around 700 or so to smooth it out a bit.
just a few thoughts.
Old Feb 16, 2008 | 03:24 PM
jcs64's Avatar
i think I would get it up and running w/ the scanner hooked up ,Then, see what you need to do.
Old Feb 16, 2008 | 03:43 PM
AUS-IROC's Avatar
Car: 1986 IROC Z
Thanks for the reply. I am running headers but before I start I was planning on getting a heated sensor. I was just reading about disabling open loop last night. I will do this until I run the engine in and get my closed loop running right.
Good point with the idle. I hadn't thought of speeding it up. That should stop it stalling until I get it running right.
After many hours of reading I made a few changes. Here is a list of what Iv done so far:
-Disabled VATS
-Disabled EGR setting the disable EGR if MAT<X to maximum temp and I set the two EGR enable if TPS>X & EGR duty cycle=0 to 0.00. Is that right or should they be set to max as well?
-Set single and double fire FI size @ 40psig to 24#
-Changed MAF tables and scalers to ARAP ones. I read that ARAP had the better tables and scalers.
Changed fan on to 180 and off to 178. I will adjust that latter to suit which ever thermostat I end up using.
-Changed crank fuel PW multiplier vs. ref. pulse. I changed ref. pulse #3 to #8 to 0.50 to help it fire faster.
Hopefully this will be enough to get me started. Than it will be a matter of tunning my fuel and ignition.
The amount of info I find on this site never fails to amaze me. It takes ages to sort out all the info you don't need but if you take the time you can always find the answer your looking for.
Old Feb 16, 2008 | 03:50 PM
AUS-IROC's Avatar
Car: 1986 IROC Z
Yeah I was planning on data logging from the moment I start the engine. I was just looking for things that people know I will need to change before I fire it up.
Unfortunately I didn't know about DIY prom tunning when I had my car running so I didn't get to test all this out on a standard engine first. I Know someone with a TPI firebird so I might try data logging his car before I start mine.
Old Feb 16, 2008 | 06:24 PM
AUS-IROC's Avatar
Car: 1986 IROC Z
Just to clarify would I run the engine in with open loop or closed loop? I will be using a heated O2 sensor.
Old Feb 16, 2008 | 06:37 PM
AC's Avatar
AC
Car: Used to drive a camaro
Get in going in open loop first. Then when you start dialing it in set the enable temp for closed loop back to the original temp.
Old Feb 16, 2008 | 09:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
PM sent
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
