AutoProm - No Hardware Found
Old Feb 23, 2008 | 09:28 PM
smithtc's Avatar
Got an AutoProm from Moates. Been fiddlin with it all day long for the most part. I have an HP Pavilion, AMD Turion 64 Mobile Processor ML-34 (1.8GHz)...Windows XP.
I've messed with Drivers, COM ports, Settings galore... Both Flash n Burn and TunerPro RT do not recognize the AutoProm.
Any suggestions?
Old Feb 24, 2008 | 06:04 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: AutoProm - No Hardware Found
Hi, go into Tuner pro then open the Tools and goto Preferences an make sure Interface type is set to Autoprom. Comm port set to Comm1 ..Target Sample Rate set to 10Hz.....See if that does the trick
Old Feb 24, 2008 | 07:25 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
here's a post I wrote a while ago...
it was on a windows 98SE computer
..should probably apply to your XP....
I would have thought that XP would work on it's own, when I got my windows Vista I plugged in the Autoprom and it worked right away. Anyway, give it a shot...
https://www.thirdgen.org/forums/diy-...light=autoprom
Old Feb 24, 2008 | 09:24 PM
smithtc's Avatar
Nope...didn't work.
Old Feb 24, 2008 | 09:30 PM
smithtc's Avatar
Re: here's a post I wrote a while ago...
Well. Just inserting the USB Cable, the laptop PC does find the hardware, etc. But the AutoProm was still not "seen" by TunerPro RT. I have tried different drivers and COM ports to no avail.
Just sharing these because I had inconsistent operation of my Autoprom...sometimes it would work great and sometimes it wouldn't.
I'm using the USB type Autoprom with a 730 ECM on a Win98SE laptop.
When I did the following it seemed to operate quite consistently:
A. STARTED THE COMPUTER AND WENT TO BIOS.
1. In the BIOS (Press F2 during startup and go to the "ports" section) I "DISABLED" COM1 and COM2. Saved changes and exited for booting to windows.
B. Hook up all your Autoprom hardware to your computer/laptop.
B. FOLLOWING REBOOT, went to windows
2. I placed a copy of the "riched20.dll" file in each of the following:
windows/system
windows/system32
progra~1/tunerprort/
progra~1/tunerprort/bins/
progra~1/tunerprort/ads/
progra~1/tunerprort/ecus
progra~1/tunerprort/layouts
2. I saved the moates drivers to their own specific folder so I could find them easily then ensured they were installed in the COM3 PORT. (Go to START->SETTINGS->CONTROL PANEL->SYSTEM->DEVICE MANAGER). Under device manager you should find COM3, go in there and set your drivers to the moates drivers per the website instructions.
3. Start your Autoprom program, select a valid bin, select a valid ecu.
4. go to TOOLS in Tunerpro, select PREFERENCES, select COM3, and AUTOPROM.
5. I would suggest rebooting right about now, leaving everything hooked up, and let the computer find the hardware and all. After the computer starts, then start TUNERPRO, it should state if it finds the Autoprom at the bottom edge of the TUNERPRO screen.
6. Once in Autoprom, assuming the computer latched onto the hardware, you can then go to TOOLS/ALDL DATA LOGGING (or press F4).
7. Once once you're in data logging, then ensure that you load the selected datastream.
8. After the selected datastream is loaded, and if everything came together properly, you should be able to connect to the ECM....it informs you if it connected.
I'm working on this right now, but it will take me a while. Thanks.
Old Feb 26, 2008 | 08:02 AM
smithtc's Avatar
Got it to work.
The planets were never aligned properly. Basically with the Comm Port set to 5, TunerPro RT set to AutoProm, started over and used the Moates Self-Install...I just needed to have the AutoProm "Switches" in the correct location (Inboard). Amazing.
Old Feb 27, 2008 | 05:25 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Originally Posted by smithtc
Got it to work.
I'm guessing you were the one that had emailed me about this? You never replied letting me know the suggestion worked. I'll take this as a yes.
Old Feb 27, 2008 | 07:11 PM
smithtc's Avatar
Maybe.
I used the contact form on Moates. Never got a reply from that. I called Craig Moates, and he left me a message of what to do. I may have emailed Craig, craig@moates.net. I emailed that address and said I got it to work and he replied back.
Not sure who you are...
I was trying last night to just datalog my car through the ALDL connection. Couldn't get it to work, but at least I know its not the hardware's fault.
Bohemian
Aug 15, 2017 05:11 PM
64Chief
Sep 12, 2015 08:05 AM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
