A/F Mixture adjustments
Old Mar 11, 2008 | 12:50 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I had dyno'd my 92 Z28 last night, came up with 282 RWHP @ 6200 and 282 RWTQ @ 4200. My Fuel Mixtures were as follows:
13.5:1 at idle
12.5:1 between shifts
10.2 - 10.9:1 at WOT.
The Dyno guy had suggested that at WOT it is much too rich, and recomended me changing that to 12.5:1 but NOT MORE THAN 13.0:1. How much HP do you suppose that can gain? Anyone had any input on that, its greatly appreciated. I have a fellow thirdgen member here who had been working with my chip & tuning it for me with his equipment.....any feedback is appreciated, thanks!
-Mike
Old Mar 11, 2008 | 01:17 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: A/F Mixture adjustments
My car, with the mods in my sig, picked up 15rwhp when the WOT a/f ratio was corrected to ~13.0:1 from ~10.5:1.
Bill
Old Mar 11, 2008 | 01:48 PM
Axle/Gears: 4.10:1
Bill
Good, i was hopin for higher #'s, maybe that'll bring me up into the 300 area! Any others? Thanks Burnout!
Old Mar 11, 2008 | 08:36 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Are you running open loop idle?? Only ask because of the 13.5:1 reading.
With the variation from cylinder to cylinder on these engines, I'd recommend keeping it in the mid 12's for AFR.
You do seem to be a bit low on power though (and torque). Might be from the driveline though.
If you had some EGT probes, you could aim leaner, if you're careful. Your combo might like it.
Definitely make sure you're not knocking. Some cylinders may be too quiet for the one lonely knock sensor to hear, so check your plugs for specks after a few 1/4 mile passes. Also, after one or two passes, avoid idling for more than a few seconds before you turn it off. Pull ALL the plugs and see if any are grey ish. That'll be your lean cylinder and will dictate whether you need to make it richer overall, just to keep that one (or more) cylinder in the safe zone.
Old Mar 11, 2008 | 08:43 PM
How do I delete a double post??
Old Mar 12, 2008 | 06:13 AM
Axle/Gears: 4.10:1
I have no idea what open loop is, sorry. As for my driveline, yah...it is kinda like a piece work for me now. I started off w/a built transmission, but my mods (at the time) only called for a stock replacement converter. So thats what it got. I got the dyno now to determine what stall converter to get, i'm currently looking into that and I should be complete with it by May. After that's installed, I may consider removing the catalytic converter from my exhaust and see if I can free up some more airflow. Then give it a final tune on the dyno again, around the 12.5 mark. I'm hopeful to dip into the 12's for 1/4mi & 1.7's for 60' with over 320 at the wheels. Thanks for all that info on the A/F, good to know!
Old Mar 12, 2008 | 09:48 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Air/Fuel Ratio Limits
6.0:1 Rich run limit
9.0:1 Low power, black smoke
11.5:1 Rich best torque at WOT
12.5:1 Safe best power at WOT
13.2:1 Lean best torque at WOT
14.7:1 Chemically ideal
15.5:1 Lean light load, part throttle
16.2:1 Best economy, part throttle
18-22:1 Lean run limit
For educational purposes only! Every engine combination will be different!
Old Mar 17, 2008 | 07:10 PM
vetteboy86's Avatar
What are the drive ability issues that goes along with running rich at WOT? I could understand black smoke, but other than that are there any signs.
Will running rich actually cause the car feel like you are starving it for fuel?
Old Mar 17, 2008 | 08:48 PM
American fuel seems to burn pretty cleanly when rich. The power drop off is slower than on the lean side. The engine may sound a bit more mellow even (not sure why, but maybe to do with the cylinder pressures at EVO). You'd have to be pretty stinking rich to WOT bog for a long time, where as lean may can stay at wot bogged forever if it doesn't stall. Lean will usually spit back into the intake too. Rich may pop or gurgle in the exhaust if it's extreme.
Old Mar 18, 2008 | 07:21 AM
Axle/Gears: 4.10:1
Heres my dyno graph, its kinda hard to see, but maybe you can see.
Old Mar 18, 2008 | 07:33 AM
Maybe you're hitting a bunch of knock at 4300+???
Or you're dropping a cylinder?
Or could be verrrrry rich, but it wouldn't do THAT in my best guess opinion.
You drop 10% in a very quick fashion. And the power still goes up after the big drop. I'd guess A or B above.
Old Mar 18, 2008 | 07:35 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
A data log would really help.
Old Mar 18, 2008 | 09:09 AM
Axle/Gears: 4.10:1
This?
Old Mar 18, 2008 | 10:30 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
No... Something like a laptop, Datamaster, and aldl cable.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
