TunerPro Datalogging and a 165 $32B
Old Mar 22, 2008 | 07:57 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I've been searching for an answer on this for a few days, and either I can't find it, or I'm a moron and have been staring at it and not seeing it, but I can't figure out for the life of me how to get my car spitting out 8192 Baud data.
My car is a 1987 IROC-Z, 700-R4, 350 TPI. Engine/drivetrain bone stock except for a performance tranny rebuild and a LS1 aluminum shaft.
I have the Moates ALDU1+CABL1 Combo and am using the latest version of TunerPro RT.
People say you can run 8192 baud on a 165 ecm running $32, but no one says how. The closest I've come says that the ecm in ALDL mode will spit out 25 cells of 160 baud data, and then look for a signal to switch up to 8192. I know this has something to do with the 10k resistor between pins A and B, and I know it has to be there when I start, but some people say to take it off (the equivalent of flipping the little switch to open), some people say to leave it on, others say it has to do with time. I have no idea.
Another thing is, which ALDL definitions file do I use? If the ECM starts with 160, should I use that? All of the $32B definitions I've found specify 160 baud, whereas it seems I can only find 8192 baud in the $6E definitions.
Any help is much appreciated!
Old Mar 22, 2008 | 09:10 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: TunerPro Datalogging and a 165 $32B
165 ECM should get you a scan every .1 sec (tenth). Try datamaster. Thats 25 different cells every tenth sec. $32 or $32B.
Old Mar 22, 2008 | 09:13 AM
tequilaboy's Avatar
In your *.ads file, is the 160 baud box checked in the ALDL Definition Header?
If so, try unchecking it. Maybe you're using a $32 ads file, instead of a $32B ads file. Are you sure its a $32B bin and not $32. Just some things to check.
I've never had an issue with using $32B and 8192 baud mode. With my akm cable and TunerProRT it works just fine and always has. I assume that the cable has the 10 k resistor built in, but I haven't checked it to be sure.
Old Mar 22, 2008 | 09:59 AM
Axle/Gears: 3.27 BW
Well, I got it to connect using the $6E ads file, and using a $32B (8192 Baud) file I found on moates.
The $32B file gives me a few screwy readings, like my CTS reading -40.00 degrees, which is normal if I have a bad CTS, but I don't. The $6E ads is reading my CTS fine but it seems less verbose than the one for $32B, that, and it *is* for a different mask than what I'm running.
Maybe I just need to keep searching for a good ads file.
Old Mar 22, 2008 | 12:28 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Edit the CTS item in the 32B ADS to match the 6E ADS CTS item.
32B and 6E share nearly idential definitions.
Old Mar 23, 2008 | 06:55 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
$32, $32B, and $6E all, are a little bit different. They will all use a different xdf file in tuner pro. If you get them mixed up, your readings will be odd.
Mark_ZZ3
May 24, 2018 01:02 PM
sreZ28
Oct 22, 2015 08:21 AM
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
