Adapting TBI to an older Chevy V8
Old Apr 14, 2008 | 06:26 PM
Brian Murray's Avatar
Car: '91 Pontiac Firebird
Engine: 4-bolt 350 TBI w/ Holley ProJection
Axle/Gears: 3.08, 10bolt
The procedure seems pretty straightforward, but I got to thinking about the distributor, and how it doesn't have a tach-drive on it (which I need in the other car), so I was wondering, if I were to tell the computer to ignore the input/output for the distributor, could it cause other problems later?
Of course I'd also need to disable the knock sensor...
Old Apr 14, 2008 | 06:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Adapting TBI to an older Chevy V8
You don't need to disable the knock sensor, just unscrew the block drain and screw it in.
Old Apr 14, 2008 | 07:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Mechanical tach drive distributor, haven't seen one of those in a long time.
You can have an EFI setup without engine timing control. However, you still need to provide a DRP to the ECM. The ECM requires distributor input to calculate the RPM, handle the crank routines properly, and to know when to fire the injectors. From points: filter it, and level convert to 5V maximum (0-5V Sq wave). Then feed it to the ECM.
RBob.
Old Apr 14, 2008 | 09:20 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
What I do is just install a magnetic pickup and reluctor from something like a Ford duraspark or a Mopar electronic distributor into mine.
Then you can take full advantage of the timing and fuel control.
The other option is to add a timing wheel to the crank and go DIS.
Old Apr 14, 2008 | 09:44 PM
90c350's Avatar
Why not just install a electronic disty and wire it correctly?? That way you will have infinite adjustability of your timing curve and wont have to worry about the details??
Old Apr 15, 2008 | 12:05 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i have to ask, other than having it, is there a reason you have a mechanical tach?
Old Apr 15, 2008 | 12:30 AM
It's a C3 'vette, so I want the tach to look stock, the electronic ones don't look right.
RBob.
I'm running HEI, so it has a tach output plug on it. I think that's a 5v square wave, though I'm not sure. The distributor is an aftermarket unit that looks a LOT like an ACCEL, but it doesn't actually have branded parts inside. I'll bet it's a Chinese copy, but it's worked flawlessly so far.
In any case, if that's all that needs doing, I think running the TBI from my old FB won't be such a problem after all. Thanks!
Old Apr 15, 2008 | 01:29 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
If you are running HEI then you can swap the 4 pin module inside to the 7 pin module for timing control and keep the rest the same.
Old Apr 15, 2008 | 10:46 AM
Really?
Not difficult, is it?
Anyone have a tutorial?
Old Apr 15, 2008 | 11:54 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I'm a little confused on your distr.
You said it's a C3 vette with a 350 running a large coil in cap, HEI distr that is equipped with a cable tach drive output, but also has the tach output plug on the cap.
Is all this correct?
I'll see if i have a large cap distr in the shop but I think all mine are the later small cap distr's.
Old Apr 15, 2008 | 03:47 PM
Old Apr 16, 2008 | 12:45 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Makes sense now.
You can lock out the mechanical advance with either a tack weld or a screw.
Then leave the vacuum hose disconnected.
Then you can remove the 4 pin module and install a 7 pin module.
The pick up wires will go to the P and N terminals and the rest will wire up as per the ECM wiring diagrams.
I didn't have a large cap HEI. I was hoping to document the conversion to keep on file. Sorry.
Did a google but didn't see a write up readily available.
I'm sure if you hit the junkyard you could find a large cap HEI with the 7 pin module and connectors you would need to make a clean install.
Old Apr 16, 2008 | 01:51 AM
Makes sense now.
I'm going to assume that any GM coil-in-cap vehicle between 81 and 90 has one, is this correct?
New2Chevy
Sep 28, 2015 12:35 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
