Will this work?
Old Apr 16, 2008 | 11:29 AM
z1colt45's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Will this work?
will this programmer i found on ebay work if i get moates' adapter and chip?
http://cgi.ebay.com/Dual-Powered-Wil...QQcmdZViewItem
Old Apr 16, 2008 | 11:53 AM
s24a's Avatar
Re: Will this work?
If it works as the Branded Willem programmer (this looks to be a ripoff clone), it should work for flashing and burning most memory ICs.
I do notice it does NOT do the 24pin DIP memory devices (eg: 2732s), so not applicable for the 1227747 style ECMs.....
Old Apr 16, 2008 | 12:00 PM
z1colt45's Avatar
Engine: 305 TBI
Re: Will this work?
well my car has the 746, and it wont matter anyways if i get moates g2 adapter right?
Old Apr 16, 2008 | 12:18 PM
z1colt45's Avatar
Engine: 305 TBI
Re: Will this work?
and it does do 2732s anyways
Old Apr 16, 2008 | 12:25 PM
s24a's Avatar
Re: Will this work?
Must have missed the 2732 in that programmer's list...
Anyway, from MOATES' site:
G2 Memory Adapter: 0.60" Leg Spacing
Allows use of new Flash chips in many GM TBI setups. If the original application accepted a 24-pin chip such as a 2732A, then this adapter will allow you to upgrade to new Flash chips such as the AT29C256 and 27SF512. Soldering required (see product web page).
So this will allow usage of larger memory ICs. Also, there is the switchable type:
G2X TBI-Type Switching Adapter
This allows the GM TBI users who use 2732A 24-pin chips as their stock application to use a 29C256 or 27SF512 chip to hold multiple programs! Must be used in combination with the EX remote switch available separately.
This will allow BIN stacking of different calibrations, and you can select which one you want remotely with the EX remote switch.....
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
