Datalogging..please help me !
Old Sep 27, 2008 | 07:30 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
Hello. I want to do a datalog with my 88´Pontiac Firebird TransAm TBI. My ECM is the 1228063. I have winaldl and an aldl-cable. Now, i´ve seen, there is no 1228063 in the winaldl-program...
What can I do ? Or should I use another programm ? Which programs are good for my 1228063-ECM ?
Thank you...
Old Sep 27, 2008 | 09:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Datalogging..please help me !
Use the data stream for the '8746.
RBob.
Old Sep 27, 2008 | 11:51 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Do you mean the 1228746 ?
Old Sep 27, 2008 | 11:59 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Yes. 1228746. That one should work fine for you. Are you able to burn your own chips? If not I recommend you contact Brian Harris at Harris Performance. www.tbichips.com or www.tpichips.com.
His phone number is 1-336-471-2827
Good luck!
What I have done in the past is email Brian my data and he modifies the bin and then i burn it. I have Moates' products to burn my own chips. Moates modified my 1228746 so i can easily remove my chip and put it in the flash/burn.
Old Sep 27, 2008 | 12:07 PM
dctrumpet's Avatar
RBob...
I have been looking at www.DynamicEFI.com for some time now. I was going to change my 1228746 to 16136965. Brian states that it's basically the same, but able to set a few parameters wider with the 16136965.
What would i need from DynamicEFI.com so I dont have to remove my chips to burn them?
Old Sep 27, 2008 | 12:13 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
I bought a chip from Brian. It works very fine.
After the saison, i want to swap my camshaft to a LT1-Cam. I know, i need another chip. Now, i want to learn to do my own chips.
It´s very interesting for me.
Old Sep 27, 2008 | 12:15 PM
dctrumpet's Avatar
Awesome! I hope things work well for you. I think I am going to convert my setup to DynamicEFI's.
Old Sep 27, 2008 | 01:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by dctrumpet
RBob...
If you are decent with soldering the self-install EBL is all that you need. There is an install guide on the site if you want to see what that entails. The only other required items is TunerPro and a laptop with a serial port. If no serial port then a USB-to-serial adapter cable works.
Note that any of the seventeen ECMs listed will work. Once the EBL Flash board is installed they are all the same. The XDF, doc's, software, serial cable, everything else comes with the package.
RBob.
