o2 sensor parameters compare heated/non-heated
Old Sep 28, 2008 | 08:52 PM
92GTA's Avatar
I'm installing a heated 3-wire o2 this weekend as a permanent replacement for my stock o2.
Has anyone done a compare of oxygen sensor .bin parameters for a vehicle with a stock heated o2 like a 93 LT1 Vette against a non-heated 90-92 L98/LB9???
I figure it would be most wise to simply copy what GM changed when they went from a non-heated o2 to a heated one.
Thanks!
Old Sep 28, 2008 | 10:47 PM
92GTA's Avatar
Re: o2 sensor parameters compare heated/non-heated
In TunerPro I just compared a 1993 Vette LT1 to a 1992 F-Body TPI and these are the only o2 parameters I could find:
Constants:
Min Cool Temp for Closed Loop - -40.00 Deg C
Min Coolant Temp for BLM Update - 80.00 Deg C
Max Coolant Temp for BLM Update - 41.00 Deg C
Min MAP for BLM Update - 5.00 Kpa
Tables:
Open Loop %Change to Fuel/Air Ratio Vs. Coolant Temp
Open Loop %Change to Fuel/Air Ratio Vs. MAP
I thought there were more in the F-Body bin?
Any thoughts???
Old Sep 30, 2008 | 09:55 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Here are some other o2 item addresses for 90-92 TPI.
The values may have more to do with the code operation that with sensor differences but worth looking into IMO.
Attached Thumbnails o2 sensor parameters compare heated/non-heated-o2-items.jpg
Old Sep 30, 2008 | 09:56 PM
92GTA's Avatar
Awesome! Thanks, I'll dig into it!
Alex
PurelyPMD
May 5, 2016 04:57 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
