Help me please
Old Dec 5, 2008 | 08:35 PM
1bad66ss's Avatar
Car: 66 Chevy II SS/89 iroc
Engine: 355/305
Transmission: 350 Turbo/T5
Axle/Gears: 3.08 posi
Help me please
Hey guys, what do I need to open this file so I can read it? When I try it's coded/scrambled stock-bin-file-88-stck88tbi.zip.
https://www.thirdgen.org/forums/atta...-stck88tbi.zip
Old Dec 6, 2008 | 07:57 AM
84KYSS's Avatar
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
Re: Help me please
I don't know if your just starting out but there are stickies at the top of the page that will tell you everything you need to know. Start with new to prom burning and then go to common questions and answers.
Old Dec 6, 2008 | 09:29 AM
1bad66ss's Avatar
Engine: 355/305
Re: Help me please
Trust me I've spent hours reading and looking for the answer to my question. I know that ppl on here expect you to do the leg work first, instead of just answering someones question.
Old Dec 7, 2008 | 07:11 AM
84KYSS's Avatar
Engine: 408
Re: Help me please
https://www.thirdgen.org/promintro
Read that then download Tunerpro RT. Get the definition for your ECM and then open the bin.
Old Dec 9, 2008 | 02:13 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Help me please
Firefox will open a zip on TGO but Explorer won't.
Old Dec 9, 2008 | 02:50 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Help me please
Yeah, I'm pretty sure you just un-zip it, then open it with TunerPro... Don't forget to load the definition file in TunerPro, before opening the file as 84KYSS said.
Old Dec 9, 2008 | 07:52 AM
1bad66ss's Avatar
Engine: 355/305
Re: Help me please
Yeah I'm sure it's real easy, guess I'm just missing something,hopefully b4 next year I can figure out the missing part
Thanks guys
Old Dec 9, 2008 | 06:38 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Help me please
Try one of these, on the bin one save it, then remove the ".txt" extension.
If this doesn't work, do a search on other bins of the same name on TGO, maybe a different link will work.
Or find someone that has a known good copy and have them PM it to you.
File Type: zip
File Type: txt
Old Dec 9, 2008 | 07:38 PM
1bad66ss's Avatar
Engine: 355/305
Re: Help me please
Let me start over and tell ya what I'm trying to learn. I'm going to swap a tpi set up into my 66. Tpi engine is out and on a engine stand, dissected the stock wiring harness to fit new application. Engine starts and runs ok, but I will need to disable some of the functions in the prom i.g. vats, vss and so on.
So in the mean time I was trying to get an idea on how to do this by experimenting with other files.
I do not have any programming equipment at this time. But have tunerpro installed on a laptop,and was trying to play around with one of those bin files.
Pehaps I'm trying to open the wrong thing? BTW the set up is off of a 89 305 with a manual tranny.
