Tuner Pro Rt log help
Old Feb 9, 2009 | 08:20 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi ,
I have been using TP/RT fo some time and i must say its a great set up, but i just purchased a "cable" so i could make use of the logging feautures of TPRT. I can "see live data BUT i cant get it to record also when i go to set up and check to see if TPrt can see my cable it says cable not present or not working, what the heck am i doing wrong. i need a bit of help to get me going, thanks GTA
Old Feb 9, 2009 | 09:30 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Tuner Pro Rt log help
Your seeing data thats good!
This may help with the rest.
https://www.thirdgen.org/forums/diy-...anner-pro.html
Old Feb 10, 2009 | 07:05 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
JP, thanks for the reply
I tried this morning and i cant get it to connect funny tho i tried a different comm port #3 it passed the cable test once and now it will not. No live data , this is very frustrating ...any more ideas thanks GTA
Old Feb 10, 2009 | 11:18 AM
JP86SS's Avatar
If its a USB cable it will default to Comm 5 on my machine.
Try each comm port and once you see a reaction from it, change the port setting "latency" per the driver instructions. IIRC it was to be set to 1.
Old Feb 20, 2009 | 10:55 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
JP hi,
well i have good news, the cable and TPRT are chatting and getting along very well, I can see and record data no problem tho i still need some help with all of TPRT's features. I do however have a question i can export the log session ( converted to a csv file but i cant open it ) i do not have excel but a different version ( quatro pro ) and my operating system is vista, any help is appreciated, thank you GTA.
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
