LV8
Old Mar 26, 2009 | 10:09 PM
TankT's Avatar
Engine: twin turbo tpi 350
LV8
In tunerpro, is LV8 = to maf grams/sec? the reason I ask is because the "minimum LV8 to enable PE" scale reads from 0-255.
Old Mar 26, 2009 | 10:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: LV8
LV8 is actually an indicator of engine load. I dont know much about the early TPI computers, but in other MAF based calibrations, the calculated load goes from 0-100% and is dependant on the airflow rate and engine RPM. High airflow, low RPM = high LV8. Low airflow and high RPM = low LV8. Its similar to engine MAP, and you can think of it in those terms.
Old Mar 26, 2009 | 11:56 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: LV8
In early MAF applications it's a loose term used to describe the volume of air traveling through the motor per cylinder per minute. It's not specifically accurate in that it's only a term used by the ecm for other calculations. So basically it's the 'load' of air going through the motor.
Old Apr 3, 2009 | 12:55 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: LV8
Also it only pertains to spark and has a 1.25 multiplier as to air flow.
Doward
Dec 7, 2004 10:35 PM
wjbecker
Mar 13, 2004 06:21 PM
funstick
16
Jun 18, 2003 07:18 PM
Sena'sIROC
Aug 12, 2002 10:06 PM
