I need chip help. I can't get the car to crank.
Old Apr 12, 2009 | 06:12 PM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
I have a motor and chip that has ran flawless until now.
The only change is a cam. I know that this is a big change though.
I have TUNERPRO, But I don't know alot about this.
I raised the numbers in the startup enrichment vs temp table but nothing happened.
1227730 ecm
custom chip
holley 4bbl intake
4150 msd throttle body
24# injectors
edelbrock rpm heads
11to 1 comp.
355 motor
cam 114ls dur @ .050 224 230
new cam
112ls dur @ .050 230 238
Car will run if you pour gas down the throttle body.
It will run until you cut it off.
no problems
BUT
When you go to crank it any, it won't run without pouring gas in it.
What do I change in the chip and how much.
I have ignition fire, I have power to the injectors on both wires while cranking. I have changed distributors to get another pickup coil. I am lost.I am thinking you can richen fuel up for startup, Don't really know?
Thanks,
Justen
Old Apr 12, 2009 | 10:13 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: I need chip help. I can't get the car to crank.
Hang on.... you're saying more or less that if you prime it manually, it'll start then continue to run - or it'll only run as long as you pour it in?
Old Apr 12, 2009 | 10:33 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You are not getting distributor pulses or VATS is enabled.
Old Apr 13, 2009 | 01:08 AM
Car: 1969 camaro
Engine: 90 TPI
If I put gas in it manually, then it will run fine. Everything does like it is suppose to. When I shut it off it will refire as long as there is fuel there. Once the fuel is gone it won't start.
I have replaced distributor, tried another ignition system, more injectors, played with the chip some, but to no good.
Car: 1969 camaro
Engine: 90 TPI
Vats is disabled in the chip also.
Old Apr 13, 2009 | 01:50 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
When you turn the key on does the fuel pump prime? Electric pump I am guessing.
Old Apr 13, 2009 | 02:18 AM
Car: 1969 camaro
Engine: 90 TPI
Yes, fuel pump primes. 50# pressure. I took the plugs out and they look dry.
Old Apr 14, 2009 | 07:50 AM
Car: 1969 camaro
Engine: 90 TPI
I have changed all the following. I am stumped
I changed the chip, injectors, distributor, ignition system, computer, and now the harness.
Still will not run on its own. You put fuel into the throttle body and it will run all it wants. Everything works right then.
Old Apr 14, 2009 | 08:57 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
I can't believe I didn't think of this....
Hook up a meter, and crank the engine. What's the voltage after a few seconds of cranking (during the crank)? If it's dropping too low (bad battery, bad ground, bad power, etc etc) your ECM will shut down and then of course not fire the injectors.
Old Apr 14, 2009 | 11:23 AM
JP86SS's Avatar
Also confirm TPS Voltage is not over 80%.
Clear flood mode will not provide fuel.
Old Apr 14, 2009 | 04:09 PM
Car: 1969 camaro
Engine: 90 TPI
I have the battery charger hooked up so it won't kill the battery. I will have to check the TPS percentage.
I am thinking it doesn't have enough cranking fuel. But I don't know which area to change in the chip. I have TUNERPRO. Is it Crank Pulse Width vs Temp?
Old Apr 15, 2009 | 10:42 PM
Car: 1969 camaro
Engine: 90 TPI
I found the problem. Thanks JP86SS. I went to check dist. pulses and I got them to the ecm but no injector cycles. Unplugged TPS and they cycled. Checked and the TPS wires were wrong. It was reading wide open throttle and therefore putting the ecm into "flood mode" and all is fixed now. Beating my head against the floor now. These things are so fun aren't they.
I appreciated all the help from you guys. I am glad that people still care about the community.
Thanks,
Justen
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Bull86
Aug 10, 2015 05:43 PM
Exxon Limited
Aug 9, 2015 08:13 PM
