How to calculate pw from ve
Old Apr 15, 2009 | 04:43 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I tried searching, but what is the calculation for converting VE into pulse width in milliseconds?
Old Apr 16, 2009 | 11:01 AM
Ronny's Avatar
Re: How to calculate pw from ve
What are you trying to research/accomplish?
Seems the PW is the result of many multipliers of the VE table. Seems the VE table is a constant of sorts to be modified by ?? coolant temp comes to mind(OL) as well as IAT(CL) as well as PE when involked.
Old Apr 16, 2009 | 11:10 AM
Car: 91 Camaro RS
For a physics class, I am trying to take those factors and be able to state a theoretical pulse width before showing the pulse width an oscilloscope.
I was trying to stick with VE table, PE, CTS tables to simplify.
Old Apr 16, 2009 | 12:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The PW equation that the (EBL) ECM uses is:
PW = BPC * ~AFR * ~T * MAP * VE (+- closed loop correction term)
It is based on ideal gas law. However, in the case of the inverse AFR and inverse temperature, there are tables that hold the actual values used in the calculation.
The $8D code does it a little differently. Directly calculating the mass of air in a cylinder (based on ~T and VE). Then applying the inverse AFR to that to get the mass of fuel required. Then factoring in the injector flow rate.
There is an article that explains SD well enough that you could put together a spread sheet for the calcs. OK, found the link:
http://marcintology.com/tuning/HowSp...ityWorks16.doc
This article explains how it is done along with showing the equations along the way. A real easy read, Marcin did a good job of writing it in an understandable form.
RBob.
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
fasteddi
Sep 2, 2015 10:29 AM
Grim Reaper
Feb 5, 2007 09:33 PM
