Project SuperAPYP
Old Apr 18, 2009 | 10:54 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Project SuperAPYP
What do you guys think about developing a better APYP bin? we can change a lot of things in term of performance.
we can extend main spark tables out 7000 rpm, better resolution for maf tables, wide band and EGT in datastream etc.
what do you guys think? let's get it started.
Old Apr 19, 2009 | 08:09 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Re: Project SuperAPYP
What about a better ARAP bin?? That is for 350 TPI motors with auto transmissions. That is what most folks here using, for TDF $6E MAF '165 ecm.
Old Apr 19, 2009 | 08:38 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I say go for it. I wish I knew something about coding to be able to help out.
Old Apr 21, 2009 | 03:28 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
How about....
1) Get a calibration perfectly matched to a bigger MAF
2) Wideband closed loop with target AFR vs LV8 & RPM, and a ECT vs MAP offset
3) Add some boost friendly algorithms (use AIR divert valve driver or some other driver for a PWM vs RPM in PE mode for a wastegate control, and another driver for blow off valve control = ON if negative dTPS is > threshold).
4) Make a speed density version for those that don't want to change ECU or MAF, and don't want to keep messing with PE for maxxed MAFs.
Old Apr 21, 2009 | 03:56 AM
Duts87ss's Avatar
Originally Posted by RednGold86Z
How about....
Sounds like you've thought about this before.
Old Apr 21, 2009 | 10:21 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Yes, please. I'd be a consumer.
Now... if only reducing such a suggestion/request to practice wasn't where these things typically fail...
Old Apr 21, 2009 | 06:38 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I like that idea.
As far as booted stuff, i do not have good experience with it.
We might have to rewrite the whole code which not a problem. I also have 68HC11 development board that I can test the new code.
Anybody wants to work with me? if you have experience in C or assembly, please let me know.
Thanks, Ivan
Old Apr 22, 2009 | 06:07 PM
Z69's Avatar
Z69
Originally Posted by 400Z28Racer
I like that idea.
How many have said that before??????
Thanks, Ivan
See Mangus's quote above
Old Apr 22, 2009 | 06:19 PM
Z69's Avatar
Z69
A group effort on the 7427 or 0411 would be infinitely more useful.
Old Apr 22, 2009 | 06:22 PM
Mangus's Avatar
Transmission: T5WC
Based on what criteria? By thirdgen F-body popularity, I'd say that the '165 and '730 are the most popular. The '730 is covered by the AUJP project.
Old Apr 22, 2009 | 06:42 PM
Z69's Avatar
Z69
- I have an 89 F body and I worked on the aujp project- extensively! -
It really depends on what you want to do..... You know a full rewrite won't get done.
Criteria
The 700r4 is too weak for serious power and traction.
CNP is so helpful for the the high HP setups/boost
165 ecm has it's problems
730 has expensive memcals - until someone figures out a DIY work around.
7427 - already has 4L80 & w\ Maf code available and more I/O space than Fbdy ecm's
0411 - CNP, 4l80, Maf and more and yet people with them get rid of the maf and like it better????
Boost code is out there for it, just have to read a chip that has it already.
Once a full hac is done with the currently available add-on OS's and tweak with desired upgrade code that been done in S_aujp and $59. This ecm will work for all sorts of setups.
But as has already been said many time by people who have been at it longer than you or me. A full hac is needed first.
It would be easier to put Maf code into aujp and have better ecm availability. Just need to get the alternate memcal thing figured.
Old Apr 22, 2009 | 06:56 PM
Mangus's Avatar
Transmission: T5WC
Isn't the primary idea here to simply upload a new bin to one's existing ECM (a '165 in this case) in the hopes of avoiding a larger than necessary swap? That's what I'd want to do, anyway.
If I wanted as much control and really wanted to go about doing a huge electronics swap, I'd go to a 749/730, MAP, and $59. Or even revert to a C3 and go with EBL.
Old Apr 22, 2009 | 07:11 PM
Z69's Avatar
Z69
A 730 is a large swap????
One of the proposed mods was SD support in 6E. Well it's easier to put maf into SD code than the other way around. The people that have already done it didn't post much if at all when I joined the board.
You can get a 6.0/4L80 complete pull out for less money than I have into my 383. Granted putting it into a 3rd gen swap isn't for everyone.
Old Apr 22, 2009 | 07:28 PM
Z69's Avatar
Z69
If your going to put the effort into a full rewrite and C... I'd say no. Others might.
Old Apr 22, 2009 | 08:20 PM
Z69's Avatar
Z69
For the mod list
All the AUJP upgrades.
Put the alt PW table from 32b back in there.
Don't get fooled into the 7k tuning thing
Some bin merge software- people are forever messing up the transfer of their current cal into the new bin.
Get with the Dewtronics author and see if/how the include feature works. -IDK-
Old Apr 22, 2009 | 08:25 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
For the mod list
Thank you for the list. I have to agree with Mangus on keeping 165 ecm otherwise I would swap to 730. Also here in California, I have to keep things legal.
Old Apr 22, 2009 | 08:48 PM
Z69's Avatar
Z69
I may be moving back to OC. Where are you?
Sniffer can't tell what ecm you have
Old Apr 22, 2009 | 09:01 PM
If this doesn't get off the ground (I probably won't be able to get much involved - I can't do assembly and I'm waay far away from my cars), I have an option for some of you...
I picked up 10 '165 ECU connectors on EBay.
My company makes an EFI ECU.
It has wideband control and 1-5Bar MAP input.
We'll be doing a turbo project soon, and maybe a MAF project (wouldn't be hard to add anyway).
We have an external box that would allow you to do 4 coils in waste spark mode or even 8 if they're module in coil (and 58x crank wheel). But that would require installing a crank wheel. A distributor will also work for those wanting to keep it simple.
We have 2 direct inputs for flat response knock sensors - so some rewiring might give you a better system.
Only 4 primary injector drivers (can do 8 injectors on 4 channels in a semi-sequential manner, if you add a cam signal - no problem). Also has 4 secondary injector drivers (but they use the same signal - so if you want to go overboard and add a fuel cell to hold E85, and run 8 more dedicated E85 injectors, no problem).
Auto trans lockup probably isn't too hard to add.
Has check engine light control too (EOBD standard), so the smog man won't really know what's up.
I might be able to add EGR and AIR control. If you want really good emissions, just install an O2 sensor downstream of the cat and let our Down O2 loop bias do the rest.
But don't let this discourage the attempt to make the '165 do all of that too. I'd help if I could.
Old Apr 22, 2009 | 09:21 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I am in San Diego. Sniffer can't tell but visual does
Old Apr 22, 2009 | 11:45 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Make it happen.
$6F could be the naming, eh? I came up on $32/6E, worked good for me.
Maybe some of the 808 stuff could be integrated.
What you want, a full disassembly? Want to get it to where you can move things around and reassemble? Do it.
Old Apr 23, 2009 | 12:37 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Last time I worked on assembly was 6 years ago, but at least I still remember the 6 addressing mode
Craig, maybe we can work on it together and get it going.
I will probably start working on it in two weeks or so, and I am going to look over 808 to see what else we can do.
Old Apr 23, 2009 | 11:49 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Getting the hac fully documented for memory locations and hardware controls is the first thing to get it rolling. Having it already relocatable is a nice thing that someone has already spent the time to accomplish.
Prepare the "wish" list and bounce it around.
A good plan for what is "possible" with the list of items to be done.
Split them up where possible and go to work.
It also helps tro have everyone using the same editor, assembler and syntax once begining code work.
Old Apr 24, 2009 | 12:22 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I agree with JP, I think some of the reasonable items are:
  • Wideband in closed loop
  • extend some tables
  • MAP enable
I am going to take a look at superAUJP features, and see what is feasible for 165.
Old Apr 27, 2009 | 04:03 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
It's already been discussed quite a bit, but the air divert removal and 02 sensor voltage change should be added to this. It looks to me like the shift light tables can be used to fire a nitrous system (I think this is something they did with Super Ajup). Maybe swapping the timing tables away from the PE timing and putting it all into one table would be a decent plan.
Old May 12, 2009 | 10:27 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I can definately see myself needing extended tables with the v6. 4800rpm is a looow ceiling for a motor that likes to live near 7k. Maybe you could extend the spark & wot fuel tables out to say... 9k? And something needs to be done with the maf tables to make swapping in a larger maf easier- reworking the code for double value (2 g/sec per bit- or more ) has been brought up before. Maybe a flag could be added to cycle between double value and normal so resolution isn't sacrificed on setups still using the stock maf?
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
