Anyone Using the APYPWB bin, for 350 auto tranny?
Old Jun 9, 2009 | 08:33 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
This is a modified bin created by one some of our expert tuners, to incorporate the linear WB output into the datastream, using $6E MAF tdf. The code does work, and there are other posts on that subject. But what I want to know, is anyone using it on a 350 TPI car with auto tranny? The orginal bin is for manual tranny, likely a Corvette.
I am having problems with my bin not locking up the TCC.
Old Jun 12, 2009 | 08:42 PM
Car: 1988 IROC-Z
Re: Anyone Using the APYPWB bin, for 350 auto tranny?
Well anyone?? I'm going to attach my bin, maybe somebody can look at it and figure out the TCC not locking. It locks but will not stay in. And I did try a fresh stock APYP bin, putting in all my values, and they same affect.
Old Jun 12, 2009 | 09:40 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Did you use the difference tool (CTRL+T) to make sure all the torque converter settings are back where they're supposed to be?
Old Jun 13, 2009 | 07:40 PM
Car: 1988 IROC-Z
No, didn't know about it. But I will now! thanks, good tip. There is just so many cool things in these editor programs!
Old Jun 15, 2009 | 08:43 PM
Car: 1988 IROC-Z
Well I used the difference tool, and found some things different between the bins. I fixed everything the same. So I flashed a chip and off I went to work today. But I still have the same problem with the TCC, it wont stay locked it, toggles in and out.
There must be something else embedded in the bin, which is NOT pulled out in the editor programs. It shouldnt be this hard to switch from a manual bin to auto. Maybe somebody could look at my 2 bins for comparison. I thought you could attach a bin in a post, but guess not. Rbob mentioned some things that needed to be changed, but I could not make sense of where he was talking.
Old Jun 16, 2009 | 07:49 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I'm using it with my auto and it won't lock either. I've adjusted things back to the way I had it before but still no locking?
Old Jun 18, 2009 | 02:27 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
The problem is not with WB hack. Mike tested a stock APYP with the same results. Anyway, I'll be working this weekend on ARAP hac to enable WB, and hopefully things will work out.
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
