EBL datalogus interruptus issue
Old Sep 10, 2009 | 10:01 AM
Ronny's Avatar
Past 3 logging attempts I get failures after about one minute of log. I need to close DL and Learm and exit WU program then shut down puter since com port is locked up. A second attempt at log and Learn is then successfull. This morning I experienced same but log and L failed after about 6 minutes.
Rough road condtions do not affect the program. Possibly the harddrive? Puter is 2 years old.
Is there a test for failing harddrive?
Any suggestions as to what it could be? I will inspect the serial to USB cable and USB socket for stable connection and see if I can prompt the failure.
Old Sep 10, 2009 | 07:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL datalogus interruptus issue
Good possiblility it is the USB to Serial cable. The high data rate of the EBL plus the noise in the auto environment tend to wreak havoc on them.
It may be the HDD. Some laptops today have anti-crash logic in them that shuts down the HDD when the vibration level gets too high. If you have a flash drive try logging to it.
RBob.
Old Sep 14, 2009 | 10:33 AM
Ronny's Avatar
I drove on some very rough roads and no interuption. this morning interrupted at idle in driveway after 20 seconds. Restarted all and was driving on smooth road and failed after one minute.
I am going to inspect the USB connection for wear and try the other USB port that I never used. Logging worked flawwessly for two years and now it pops up?
Is there a test for determining if HDD is failing intermittantly?
Old Sep 14, 2009 | 11:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On XP can scan for bad sectors. Settings, administrative tools, computer management, right click on volume, properties, tools tab, error checking, check now... button.
RBob.
Old Sep 21, 2009 | 02:46 PM
Ronny's Avatar
It fails about 2 in 4 datalogs. failure so far only on cold cold start.
It states devise is working properly. suggests I may want to reinstall driver or use prior driver if new one is causing an issue.
How about changing settings? currently port settings:
bits /sec 9600
data bits 8
parity none
stop bits 1
flow cotrol none
Old Sep 21, 2009 | 03:55 PM
Ronny's Avatar
I just deleted about 120 logs of on average 15 min each. Is it possible I had a memory issue?
Old Sep 21, 2009 | 06:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The port settings won't matter. They are set up by the WUD.
Running out of hard disc space would do it. Although IIRC, there is a popup warning if that occurs.
RBob.
Old Sep 22, 2009 | 09:09 AM
Ronny's Avatar
As stated I had two failures yesterday in morn. I then deleted 90% of files and used a different USB port. I was thinking maybe one had a connectivity problem either with cable or port wear and tear. Yesterday pm and this morn no failures.
Old Sep 23, 2009 | 11:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Had a thought, try doing a defrag on the disc. It may be that the HDD has to go all over the platter to save the data log, which isn't leaving enough time for the USB driver.
XP and Vista has a defragger as part of the admin tools.
RBob.
Old Sep 23, 2009 | 11:18 AM
Ronny's Avatar
logged again this AM 22 min and no issues! thank you will do that if it fails again.
Old Oct 1, 2009 | 09:34 AM
Ronny's Avatar
OK. Multiple faiure of datalog. Fails in about 3 min. I did attempt the defrag. Please let me know if this is correct.
1.Administrative tools
2.Computer management
3.Disk defragmentation
It is now defragmenting. Very slow about 1% per minute. It is doing only (C?
I assume I then need to do My documents (D after C completes?
Old Oct 2, 2009 | 04:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is funny how the forum took the drive designators and turned them into smiley faces. Some things just don't work the way we want them too.
As for the D drive. I would also do it.
RBob.
Old Oct 5, 2009 | 12:18 AM
71403's Avatar
Engine: X
Transmission: MT1
Newer hard drives have onboard diagnostics called "SMART". There are a number of free tools to view the historical statics as a way to predict failure.
http://en.wikipedia.org/wiki/S.M.A.R.T.
This is one of the plain-jane ones:
http://www.beyondlogic.org/solutions/smart/smart.htm
Old Oct 5, 2009 | 11:31 AM
Ronny's Avatar
fragmentation did not work. 2 failures this morning. should I uninstall the drivers for the usb cable and reinstall with the CD that came with usb cable?
otherwise the lap top works flawlessly soo I suspect the hard drive is OK.
Quote: On XP can scan for bad sectors. Settings, administrative tools, computer management, right click on volume, properties, tools tab, error checking, check now... button.
I will look again. I would expect it would flag any area that does not meet the test.
I will physically move the usb male to female connection to see if I can get a connection failure. unlikely IMHO.
any suggestions?
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
85Special
Sep 3, 2015 04:21 PM
