What did I do wrong?
Old Nov 8, 2009 | 10:26 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
I just now went ahead and finally soldered in my g2 adapter as well as programmed a chip with the ANLU bin file from moates.net and when I turn the key, the CEL blinks like mad. From what I had read, that was supposed to be something bad right? I thought I read that it could be from the program on the chip being messed up so I tried a different version and even th program that was running before (ANTT) and it's still blinking like crazy! What the hell did I **** up? Any help would be greatly appreciated as I need to try everything I can to fix this tonight so I can go to work tomorrow. thanks,
Eddie.
Old Nov 8, 2009 | 10:44 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Re: What did I do wrong?
I just posted a bunch of pics to my photobucket account from the solder work. Maybe I goofed something up there? http://s228.photobucket.com/albums/e...sirus5164/ECM/
Old Nov 8, 2009 | 11:04 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
What chip are you using?
Are you using the correct offset?
The offset has to be correct to place the bin file at the "end" of the chip.
Old Nov 8, 2009 | 11:05 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
How exactly do I use the Offset? I'm using FlashnBurn.
Old Nov 8, 2009 | 11:18 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
I took a screenshot of what I've been doing when I burn the chip? the chip says 27sf512.
Old Nov 8, 2009 | 11:28 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Looks like you may have some soldering issues. In picture 9 it looks like the middle 2 pins may have lost the solder pads on the boards foil pattern. If that is true, you may have to carefully scrape the coating off of the foil on each side of the prom adapter pin and bridge across with a fine strand of wire soldering it to the foil on each side and the adapter pin.
Old Nov 8, 2009 | 11:32 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
I thought that was burned adhesive from where that quark square used to be attached
Update: I put the original chip back in and the CEL stopped blinking. I can assume that the problem lies with the burn right?
Old Nov 8, 2009 | 11:48 PM
Yes, it is an offset problem then.
http://www.moates.net/documentation....entation_id=75
Old Nov 8, 2009 | 11:51 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Well, I can not be sure from the pictures, but it does not look good to me. Also, Six_shooter may be correct that you are not using the device addresses correctly. I have not used this setup so I can not answer the details on how to do that.
Old Nov 8, 2009 | 11:55 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Originally Posted by Six_Shooter
The offset is in the upper right hand corner of the program right? I thought all those offsets looked like what the chart said they were supposed to be. I don't know, my weekend is almost over and I'm getting a wee bit frustrated..ha ha!
Old Nov 9, 2009 | 12:17 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Update: I went ahead and reburned my bin file to another flash chip. I don't know if the other one may be FUBAR or what but it's running fine with the other chip.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
