$6E mask
Old Jan 1, 2010 | 09:24 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
$6E mask
I'm having a hard time finding a stock $6E bin file for an '89 LB9/700r4/3.23 combo. I've been searching for a couple of days with no luck. Can anybody point me in the right direction to one?
Old Jan 1, 2010 | 11:13 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: $6E mask
Have you looked at www.moates.net?
http://www.moates.net/fileman/index.php?dir=1) Stock Binaries/DIY-EFI GMECM Binaries/1227165 32 32B 6E 94/6E
Old Jan 1, 2010 | 11:56 PM
DBLTKE's Avatar
Engine: LB9, LB9
Re: $6E mask
Sure have. The problem is that the files don't have a description for them and I can't just look at the 4 digit code off of my car, because the 165 ECU I have is from an '87.
Old Jan 2, 2010 | 09:57 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Re: $6E mask
Use the search function and type in "prom bcc". Might help narrow it down
Old Jan 2, 2010 | 10:37 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: $6E mask
www.chevythunder.com scroll down on the first page about half way and you should find "prom BCC codes -TPI", click on 1989 and several codes will pop up for F and Y bodies.
I'm attempting to attach a screen snapshot
also, ARAP when looked at in TunerPro has the injecters set at 22 which is for a stock 350 and also has TCC values in place for the auto transmission.
I hope some of this helps.
86White_T/A305
Mar 6, 2016 01:48 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
camaro6spd
Mar 27, 2003 09:52 AM
Twilightoptics
Dec 8, 2002 10:00 AM
