PROM help
Old Feb 8, 2010 | 07:48 PM
coreyvincelette's Avatar
Car: 1987 camaro
Engine: 5.7L 350
PROM help
hi im corey i was wondering if i could take a prom chip from a corvette and put it im my 87 camaro z28 irocz 5.7tpi
Old Feb 9, 2010 | 01:07 PM
Ronny's Avatar
Re: PROM help
1987 Vette and Camaro for 5.7 TPI both used 7165 ECU. But I recall Vette is aluminum heads and Camaro is iron. Is that correct? If so the timing in Vette chip may be too aggressive. You may be able to retard at distributor to get it closer to Camaro? Also the trans in chip must match.
Old Feb 9, 2010 | 10:48 PM
ULTM8Z's Avatar
Re: PROM help
If the 7165 ECM's are anything like the 7730's, there's probably a parameter in the cal similar to "Spark Latency Time Correction vs RPM". IIRC, This parameter deals with the different diameter distributor caps. For a given engine rpm, the tangential velocity of the large cap HEI rotor is faster than the small cap rotor (due to the larger diameter). The spark timing takes this into account within the ECM. The ANHT (90-91 Corvette) and the AUJP (90-92 Camaros) have different values. Not sure the impacts of neglecting to adjust this.
Old Feb 10, 2010 | 02:12 PM
Car: 1987 camaro
Engine: 5.7L 350
Re: PROM help
ok so any sudgestions of cheap performince mods?
Old Feb 10, 2010 | 08:17 PM
ULTM8Z's Avatar
Re: PROM help
To the engine or to the calibration?
Old Feb 11, 2010 | 07:09 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: PROM help
It should work fine if you have VATS in the Camaro. All vettes had VATS in 1987 but not all Camaro's. I used to swap my Vette and Camaro chips back and forth before I started tuning my own chips and I never had a problem.
Old Feb 11, 2010 | 11:00 AM
Car: 1987 camaro
Engine: 5.7L 350
Re: PROM help
its tpi so any
Old Feb 11, 2010 | 02:05 PM
ULTM8Z's Avatar
Re: PROM help
Well, if you're running 2.73 axle ratio out back, I'd change it to at least 3.42. IMO, you'll get more bang for the buck than anything you do to the engine (for equivalent $ spent).
Old Feb 11, 2010 | 04:41 PM
Car: 1987 camaro
Engine: 5.7L 350
Re: PROM help
im running stock
Old Feb 14, 2010 | 10:35 PM
1badz71tahoe's Avatar
Re: PROM help
Ronny,
Why would you want to retard at the distributor? For the 7427 (all i've been studying on for a while) your suppose to (Courtsey of Fast):
Next it is time to setup the timing table. For a mildy cammed engine I typically setup the distributor at 6* advance and set the corresponding initial timing setting in the ECM at 6*. This allows for quicker starting with a cold engine but does not put excessive drag on the starter at other times. The initial timing on the distributor and in the PROM MUST match or it will mess with the whole timing advance curve.
Isn't retarding the timing @ the distributor lying to the computer essentially negating any reason to do the above regardlessly?
Just curious, as I know YOU know more than me!
- B
Old Feb 16, 2010 | 09:17 AM
Ronny's Avatar
Re: PROM help
I assumed he was not into burning his own chips. My first chip was a hyper and it suggested advancing SA at dist a couple degrees, maybe three. So, I believe hyper chip only did the fueling. Ideally he purchases correct GM chip or get into tuning and pull correct one of off Moates site.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
