350 H.O. idle stall
Old Apr 2, 2010 | 11:52 AM
rokcrawlin85's Avatar
Car: 85 chevy k5
Engine: TBI 350 H.O.
Axle/Gears: 4.10
350 H.O. idle stall
im working on getting my 350 h.o. tuned in using tunerpro. i've got my blm's in the 400-3000 rpm areas from 20-70 map areas pretty dialed in to 128 give or take 6. im having a problem getting it stay idling when i put it in gear and coming down to a complete stop. in park it idles fine. it usually stays running in gear but its constantly trying to save itself.
im running the 8747 ecm with 4F.
maybe just some general areas to look at for idle stuff in the bin would be great.
i've got the target rpms at normal running temps set to 650.
Old Apr 3, 2010 | 10:22 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: 350 H.O. idle stall
I doubt this is much more than a poor partial answer.
Having had similar issues in the past trying to get "Shammoo" it to idle at 600-650, I came up with the simple answer that it was happier idling at 800. No doubt in part due to the cam, split pattern 230/236 and much more overlap than stock.
Touch your pedal to come up to 800rpm or 850. See if the engine is as Grumpy would have said, "happy" more content at a slightly higher rpm at idle. If so, perhaps resetting your target idle might be helpful.
WORDS of WARNING and CAUTION! I'm a rookie, and most anyone here is better qualified to help you than I am.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bryan F
Aug 18, 2015 02:28 PM
