Moates G1 Memory Adapter for TPI
Old Jul 4, 2010 | 12:56 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. I need some help before I order some parts from Moates. So here we go.
1. Do I need to buy a ZIFF socket to install a programmed EPROM into here, or is it ready to drop in a EPROM?
2. Which Ziff socket do I choose?
Old Jul 4, 2010 | 02:07 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Moates G1 Memory Adapter for TPI
Reply, no you don't need a ZIF socket. The EPROM will attach directly to the G1 adaptor just fine.
The only reason for a ZIF socket is if you planned to swap EPROMs often to dial in the tune. If you don't plan to do that, then don't worry about the ZIF socket.
Old Jul 4, 2010 | 10:31 AM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
S2 Aries 28-pin ZIF Socket is what you will need . Once you start pulling the chip out a few times it is hard to keep the legs on the chip straight .
Old Jul 4, 2010 | 11:58 AM
Ok. Well I do plan on switching out the EPROM every once in a while so Ill get that ZIF that was mentioned. Thanks guys.
Old Jul 4, 2010 | 04:17 PM
You could get the GP1 package then, that comes with a ZIF socket and two EEPROMs. http://www.moates.net/product_info.p...products_id=41
Old Jul 4, 2010 | 04:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
IIRC, with the Aries socket on there, you can't put the slot cover back on the ECM.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
bnoon
May 23, 2003 01:53 PM
Chop_Top
Jun 18, 2002 06:39 AM
